$25k as roller, or $30k w/ newly converted Stohr P2 floor with latest diffuser
Chassis #001, the first production WF1. It comes with full carbon fiber bodywork; two sets of Jongbloed wheels; DSR floor with tunnel blockers to run P2 class; dual-element rear wing fabricated from previous WF1 rear wing components, and new HRP single element rear wing as a spare; WRD differential; front and rear quick jacks. Newly installed are radiator, oil cooler, front brake rotors and drive pins all around. Headers and engine mounts are for 2007/08 GSXR. Full mechanical paddle shifting by way of single cable. Custom driver head surround that is padded and hinged to swing up for easy ingress/egress. Data logger is Aim MXL Pista with GPS. The chassis is light, straight (no evidence of crash) and fast with lap record in P2 configuration on 3/7/15 @ NOLA Majors (record beat in 2018). Car raced at Runoffs as DSR from 2006-09, finishing 3
rd (starting 8
th), 5
th (starting 7
th) and DNF (starting 5
th), respectively. End of race weight without driver is around 800 lbs.
The bad: bodywork and P1 floor have been patched and are rough when up close. Fuel cell capacity is 5 gallons and is poor fit, should be changed out for larger capacity and proper fitting one.
Car purchased in mid-2014 as my backup and raced outside of Florida on an arrive’n drive basis until 2016. Previous owners include Dorian Foyil, Tony Branco and Gianpaolo (J.P.) Ciancimino. My crew chief has fully gone over the car, so just drop in your engine and it is a fully competitive P2 car. Other option is convert the car to Hayabusa power, which I considered before going a different path. Car is located in Miami, FL
Links to previous for sale posts:
https://www.tapatalk.com/groups/dsrf...le-t10420.html
http://www.apexspeed.com/forums/show...846#post439846
