Van Diemen RF78 CFF- Frame-Up Restore
Frame-Stripped, inspected, repainted.-
Transmission - Replaced Ring &Pinion - safety wired ring - new shift dogs
Engine - New Rings, Main & Rod Bearings, Full Valve Job, springs, seals, Rocker ratio corrected; Water expansion tank, new exhaust system designed for outboard suspension to max power. twin water pump belt system.
New ATL fuel cell - all new gauges, Oil Pressure, oil temp, water temp and RPM. New seat cover, new removable steering hub.
Full wheel alignment at 180 pound driver
New Black aluminum sides with nose painted to match.
Personalize this racecar to your taste with new seatbelts to your style & color, plus your choice of color of center body and a new battery at NO cost to new owner!
Spares include - alignment bars, front steering rods, rear camber links plus three extra gearsets.
All work done at Formula Haus. Racecar is at Hagerstown, MD E-Mail
ajp241@yahoo.com or call 914-576-1916
Price is $17,750.00 Attached Thumbnails
