Results 1 to 14 of 14
    Maine
    Default What safety belts do you use?
    I need new harness/belts in my car and am curious what you've found to work. I just bought a set of G-Force pull-downs from Summit and they're *way* too big for a small formula car. Thoughts?
    (thanks)
    Columbus, OH
    Liked: 482
    Quote Originally Posted by Frank06 View Post
    (thanks)
    I have a set of Willans that are very very nice. Now, I haven’t raced with them yet but I’ve been in and out of the car literally dozens of times in the past two weeks getting the cockpit set with all my gear on.
    That said, I will seriously consider Crow when I need a new set for the following reasons:
    I understand they reweb existing sets for a reasonable cost
    They are reasonably priced from the get go
    They will build you just about whatever you want if you call
    US company
    Senior Member Farrout48's Avatar
    Florida
    Liked: 133
    I like the Schroth Hybrid. The 2" lap belts are pull-up so I can tighten them after I get belted in. Since I do not have a crew, it makes a huge difference for me. I like that a lot better than the fixed lap belt. Shoulder are the Hans 2" as well.
    EDIT - I just noticed that the Hybrid has been discontinued.
    Maine
    Thanks for your replies. A friend gave me a 10+ year old set of Willans and they are indeed very nice, just pricey. I hadn't heard of Crow and will look into both those and Schroth.
    Last year when I needed to update I spent some time looking at different sets here:
    https://www.demon-tweeks.com/us/moto...y/recommended/
    I ended up getting a set of Sabelts and I'm happy with them, and the price was very reasonable.
    I have had Willans and TRW in the past and they were nice, too.
    Liked: 947
    Default Omp
    Have a look at OMP. They make a bolt in set with pull up lap belts and 2" HANS shoulder belts. The adjusters and buckle work really well.
    Liked: 1262
    Bot Sabelt from Primus last year. I like them better. Different buckle up procedure. the main buckle is on a lap belt instead of the shoulder so you're not flinging the buckle out of the cockpit and bashing it against the side of the car.
    Hudson, Ohio
    Liked: 208
    Default Sabelt
    About to replace my harness. I have used Willans, Sabelt and OMP in the past. Going with Sabelt this time around because I like the adjustable lap belt.
    Ralph Z
    1968 Alexis Mk14 Formula Ford
    Maine
    You guys are giving me lots of options, thanks.
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 610
    Default Replacement Belts
    Quote Originally Posted by Ralph Z. View Post
    Most single seaters I have seen don't have room for lap adjusters or they ride on your hips.
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
  14. #11
    Florida
    Liked: 133
    In my Stohr WF1, there is ample room such that I have SpeedSeat material on the sides of my hips . I did have to carve out a pocket for the lap adjusters because my hips were compressing them into the seat sides. After opening up the pocket, I did not have any further lap adjuster binding issues.
    I also used the pull up lap belts in the Euroswift FF I had. A bit tighter but the belts worked well in that car.
  15. #12
    Columbus, OH
    Liked: 482
    You know, a lot of local club guys have their just outdated lying around you could borrow and try to see what you like.
    I’ll send you mine if you want to pay shipping but I bet you could find some around you free.
  16. #13
    Placentia, CA
    Liked: 341
    US company
    Crow does indeed recertify. I had mine done at the beginning of this season. For info, check here: http://www.crowenterprizes.com/pages/Recert.html
    There is a PDF there with the process, options, and prices. $70 for formula belts and that is what I paid. Came back in perfect order. I had them cut off some of the excess as the original was a bit too long. Very easy to work with the folks there. Best part for me is they are within 10 miles of my house so no shipping.
    I will happily continue on with Crow from my experience.
    Eric Little
  17. #14
    Maine
    Thanks for the offer but I've actually just tried an old set of Willans I stumbled onto locally. Getting actual measurements will help tremendously.
