Hello,
I'm starting the removal of my MK9 and have run into a snag. It seems as though the cap overing the inside CV joint would just slide off but I tried a hand pry bar now afraid of damaging the rim of the cap. Any tricks here to remove the shaft from the trans? Do I use the weight of the carrier to pull out? I have all the links, shock, calipers undone and ready to swing it away but a little stuck here (pun intended) Thanks in advance.
Todd Buttrick
