Hello to the forum, Are there any members using the following configuration for the Hewland Mk.9: The all aluminum "Rhino" case, a Quaife ATB, and a set of the Hewland " MK.5", the " heavy duty" gearsets? If so what type of engine, 1.8, 2 liter, or, are you using with this set-up and how much torque seems to be OK with this set-up? Appreciate any insight or info you might provide as to this question. Will this set-up take the torque of a highly modified 2 liter if you can avoid sudden or standing starts? Cannot locate a FT200 or FG unit that is not being pedaled by "scam artists" on the net and wondered about this set-up. Thanks, jerry
