I consistently get a bubble in my oil line (the 5/16 line from the oil tank to the engine).
At Heartland, I noticed bubbles going backwards up the line to the oil tank after the Sunday race (when I was loading the car, so it'd been 15 minutes since the race).
I replaced the line and put new zip ties on the fittings to try to make sure they were sealed.
I also drilled a hole in the cap of my oil tank to let air in, since I thought maybe it was creating a vacuum pumping the oil out. That leaked oil all over everything, and I put a shop towel over the hole to try to limit the leakage.
Unfortunately, there was a bubble after the Saturday race (which I bled before Sunday), and another bubble now after the Sunday race.
I do have a return line from the engine (it is a 593). The oil tank is higher than where the oil goes in to the engine, but the line goes down under the axle (my tank is mounted on the back of the frame) and then up to plug into the engine (since that faces up).
Does anyone have any suggestions about what to do so that I don't get the bubble? The current one isn't the full width of the hose, but maybe only 1/3 has oil and 2/3 air (at the top of the bend).
