    cambridge, massachusetts
    Default Engine oil to heat exchanger
    The ports under the clutch, is one an inlet, one an outlet
    Will
    Lapeer, MI
    Liked: 91
    Yes that’s correct
    which is which? Don't have a manual with me.
    Will
    Lapeer, MI
    Liked: 91
    I need to check but I believe the front port is the out and the rear one is the in.
    Do you have the fittings?
    https://www.summitracing.com/parts/vpe-16634
    Have all the fittings and hose. Just want to plumb the right line to the top of the heat exchanger.
    Will
    Lapeer, MI
    Liked: 91
    Will,
    I did verify over the weekend that the front oil port is out and the rear one is return.
    -Eric
    Thanks, Will
