does anyone have a full manual for the SLR82 and the SL75 gearbox they can share.
Here you go. This is for the SL75-14 LW, but I imagine the SL82LW is not much different.
https://www.dropbox.com/s/aeseg006ww...ES-F4.pdf?dl=0
Brandon
Brandon, thanks for the link to the SL75 gearbox manual. The SLR82 gearbox will be completely different, well at least it should be considering the torque capacity is almost double. different case etc....
if you hear of that manual anywhere please keep me in mind
thanks
simon
I just installed a new SL82 in our NP01. it is virtually identical to the 75 that we took out. One difference is the neutral lock out cable is on the right side of the 82 and left side of the 75.
Unfortunately, there has been a recall on the transmissions for a under designed input shaft. Sadev has been very honest, and transparent, regarding the issue and will be replacing the part as soon as it is available.
BTW, I have a very low time SL75 for sale is anyone is interested.
Scott
Simon,
You're right. I was interjecting letters where there weren't any and thought you were asking about the SL82LW. That gearbox is essentially a SL75LW with SL82 gears. I had researched the SL82 a few months ago and thought I had found a manual. I'll look for it...
Brandon
maybe there is confusion with the letter identity
so there is a SL75 with the gearbox at the rear of the case and the diff at the front
then there is a SLR82 14 with the gearbox at the front of the case and the diff at the rear
