Results 1 to 9 of 9
    Liked: 433
    Default Cleaning Magnesium Calipers
    Hi all. I have some magnesium brake calipers and master cylinders that have been sitting for a while. What is a good solution to put these in and let them soak for a while to clean them up before re-kitting them? They are Airheart brand. Thanks for any help.
    Graham
    are they corroded or just dirty.
    if just dirty, they should come pretty clean in the normal parts washer solvent with perhaps a bit of elbow grease.
    Liked: 433
    Mainly just dirty but with a little of bit "gelled" brake fluid in spots. I know you can't use distilled or rain water on them because that will corrode them. Being as rare as they are I don't want to mess them up.
    Graham
    Ossining, New York
    Liked: 20
    I cleaned up some old AP calipers (aluminum I believe) and also master cylinders that had crusted brake fluid from many years of sitting. I read somewhere that denatured alcohol is good to dissolve crusted on brake fluid, and I had good luck with it cleaning up my parts. I have heard that methanol can be corrosive to aluminum (denatured alcohol can have some methanol), so I was careful not to soak my parts too long. I didn't notice any issue with overnight soaking. Again this was aluminum, not magnesium. Maybe try wetting a contaminated spot on a caliper instead of soaking to see if it works and to confirm no damage?
    Scott
    Somerset, Kentucky
    Liked: 126
    I've never seen a magnesium brake caliper... but I used to clean up mag intakes on mechanical fuel injection Porsches with paint remover. It doesn't take long... don't let them sit in it.
    Liked: 433
    Thanks for the responses thus far. Here is one of the calipers for reference.
    Graham
    Liked: 1878
    Ossining, New York
    Liked: 20
    One thing that occurred to me after I wrote earlier. Some folks (including me) have tried Pine Sol as a parts cleaner. It works nicely. But don't try it on magnesium parts. Apparently it dissolves magnesium somewhat aggressively!
    Liked: 433
    Thank you for the links. I will follow these up.
    Graham
