Kirkey, UltraShield or any other Aluminum seat will mount directly to the lowest point in the flooring. If you have cross tubes under your seat, then that is about it. You can tell your situation by what your current seat mounts on. The only other way to get your head lower is to increase the seat back angle and move your butt forward. Of course, that capability assumes you have the legroom or pedal placements to do it. I had an Ultrashield aluminum seat in my Legrand DSR. Moved it forward and tilted it backward to get the head clearance I needed to road race it.
Broomstick rule is generally used for helmet clearance. Run broom stick from top of rollbar to where it lays on forward most part of frame. Head should be under it for safety purposes. For SOLO, this is not generally checked unless your head is definitely above the rollbar.
Take the seat out. Sit as low as you can. Place your butt such that your helmeted head is as low as you need it and you fit in the car, etc. If everything works, then you use foam padding or make a backrest, etc to support your self.
