Working on a project PFM and need to install the shifter linkage. Could anyone please provide pictures from cockpit to gearbox showing routing and appropriate hardware? Thanks in advance!
Can't find a photo at the moment but it runs from the shift lever back to the hole in the upper corner of the rt side of the tub. Thru the hole then we ran them on the inside of the intake manifold, down over the bellhousing to the mounting bracket on the side of the gearbox. Rod end connects to the belcrank on the gearbox with appropriate shims to take up the gaps above and below the rod end.
The front of the cable connects to the shift lever with one of two different shafts. The later design has the shift cut switch internal to the shaft and the earlier design has the switch mounted to the side of the tub.
I can send photos later this week if you still need.
Mikey,
I sent you my email via pm.
Jerry
