Results 1 to 5 of 5
Thread: Oil Cooler
    Fallbrook, N. San Diego Co.
    Default Oil Cooler
    When I run here in the San Diego/LA area, and the weather is extra warm, I get my oil temp up pretty high. I was thinking I could set up an oil cooler with a bipass valve(or 2) for when I don't need it. Anyone tried this, or have any opinions?
    Mark
    Liked: 946
    Mark
    Mark,
    How high is "high temperature?"
    Mark,
    My sensor is at the outlet from the bottom of the oil reservoir and occasionally it gets up to 210, but this is usually accompanied by high water temp and I can't do anything about that except add a fan and that blocks the air flow when not turned on. I got a private message about an oil thermostat that is fully open at 180 which seems good to me. What do road racers do?
    Mark
    Liked: 946
    Mark
    Hello Mark,
    Save weight and your money. 210F is normal, actually ideal! I would not be concerned until oil temp was over 250. Cold oil costs you HP from parasitic losses. Art Smith recommends heating your oil above 190 before you send the car on track. You would need a fan on the oil cooler for it do do much good anyway. That's more weight, another failure point and complexity.
    An oil cooler is just another point of possible failure or leak. Without an oil cooler in the Crossle or Zink, my data shows 225 at its highest during a 40 minute race on a 110F day.
    As another autocrosser/racer Neil Roberts said, "If it's not on the car, it can't break."
    Regards,
    Dan
    Hello Mark,
    Regards,
    Dan
    Thanks, Dan. My local FF mechanic said not a problem so save the money.
    Mark
