Dan, thanks for the detailed, first-hand information--very valuable.
I guess I should update my spreadsheet for Club FF. I had the AR tires down for 20 heat cycles based on what you said
here. But the number was my interpretation of what you said--"3 weekends". Since my scenario is 8 sessions per weekend (three practice sessions on Friday; practice, qualifying, and race on Saturday; and qualifying and race on Sunday), I converted "3 weekends" to 24 sessions (heat cycles). Which sounded optimistic to me, so I rounded down to 20.
From what you're saying, the AR's are only competitive for 15 heat cycles.
If so, that would really change the cost of the AR tires, from $196/weekend to $261/weekend.
I have the Hoosier FF-spec tires down for 20 HC, and so $306/weekend.
If this is all correct, then the AR's aren't saving nearly much as I thought they were. Now total operational cost for this car would be $439 with the AR tires, or $484 with the Hoosiers. Only $45/weekend difference, or about 10%.
If the AR tire creates the problems you describe, then maybe the $45 savings is not worth the hassle.
On the other hand, the AR's are quite a bit lighter than the Hoosiers.
What are you thoughts on the trade-offs here?
The lap-times look about the same to me, based on Thunderhill lap-records. FF is 1:53.815 (2016-5-14 Chuck Horn in a 1993 Swift DB6 with Honda engine), and CF is 1:54.787 (2011-4-9 Denny Renfrow in a 1972 Crossle 25F). Just 0.972 second difference. I assume FF in 2016 would be on the Hoosier FF-spec tire, and CF in 2011 would be on the AR tire. Since the Swift DB6 has much lower drag than the Crossle, I think the 1 second difference should be the cars, and the tires appear about equal to me.
Is that right?
Greg
