My mechanic said he didn't have time to change the inner CV joints on my 90 Van Diemen because they were too stuck. Anyone else run into this problem and have a solution?
Mark
Mark
Someone may have used sealant on the faces to keep them from leaking grease. I pulled the boot flange away, warmed the joint with a heat gun and used a rubber mallet while turning the wheel.
I put it back together with a thin film of blue hylomar. Doesn't leak.
Regards,
Dan
How much time did your mechanic have available to change them? An experienced with your car mechanic could make surprisingly quick work of it.
Was it the CV race 'stick' to the axle splines? ....... Simply use a press to push it off.
Hey Mark,
I laid down my CV joint on top of a vice with some rags and tap the axle out with a light hammer and punch very easy.
Ben
Sort of an argument for regular maintenance, no?
Charlie Warner
fatto gatto racing
