Results 1 to 10 of 10
    Fallbrook, N. San Diego Co.
    Default Removing CV joints
    My mechanic said he didn't have time to change the inner CV joints on my 90 Van Diemen because they were too stuck. Anyone else run into this problem and have a solution?
    Mark
    Liked: 942
    Mark
    Someone may have used sealant on the faces to keep them from leaking grease. I pulled the boot flange away, warmed the joint with a heat gun and used a rubber mallet while turning the wheel.
    I put it back together with a thin film of blue hylomar. Doesn't leak.
    Regards,
    Dan
    Senior Member Nardi's Avatar
    Southeast
    Liked: 121
    How much time did your mechanic have available to change them? An experienced with your car mechanic could make surprisingly quick work of it.
    Howell, MI
    Liked: 218
    Quote Originally Posted by Nardi View Post
    I'm also surprised by the reasoning... it's not usually a particularly time consuming job.
    www.wrenchaholics.com
    Rental, Coaching, and Data Analysis for Great Lakes Region
    Contributing Member TeamFRD's Avatar
    FL, USA
    Liked: 15
    Was it the CV race 'stick' to the axle splines? ....... Simply use a press to push it off.
    Quote Originally Posted by MotorCade View Post
    Thanks for all the input. Mechanic was trying to get the car back to me to drive it. I will talk to him for the next time. I do not have a press, so nee his help.
    Liked: 942
    I'm not sure why one would need a press to disassemble a CV joint from a hub or the axle.
    Regards,
    Dan
    Senior Member Buc01's Avatar
    Moore, OK
    Liked: 73
    The job is easy. Do it several times per season on 1991 VD FC.
    Aaron
    San Jose Ca
    Liked: 80
    Hey Mark,
    I laid down my CV joint on top of a vice with some rags and tap the axle out with a light hammer and punch very easy.
    Ben
    Memphis, TN, USA
    Liked: 413
    Sort of an argument for regular maintenance, no?
    Charlie Warner
    fatto gatto racing
  12. The following 4 users liked this post:
