?2015 LMR001 is back on the market. I traded for this car and realized that I do not need two cars at this time. I can say this is a very clean car with only a handful of weekends total. From the previous owner some time has been spent on development. Car originally came set up for endurance racing, but prior owner has removed all the extra items off to use it in sprint races in the SCCA and NASA. Car comes with all the log books, molds, and cad files
asking 20k or best offer. will also consider trades for a towing vehicle or street car.
will consider any reasonable offer or trade
car is located in Northern California
you can reach me at
veloceracing@att.net
206-218-7935
or PM me as well
Sammy
Quick Specs :
Weight:1050
HP: Apx 160-180hp with stock hayabusa
Has APE clutch kit with stronger springs and stiffening plate
Motor has about 3 hours from me and from what i understand low hour motor to begin with, also just preformed an inspection and the parts have almost no wear. everything is in spec
seat is ultra shield
Chassis - 4130 Cro Moly tubing tig welded. Chassis components were CNC routed so fitment was perfect in every joint.
Body - All Carbon fiber with Foam core. All vacuum bagged (Molds go with car)
Engine - Gen 1 Suzuki Hayabusa. (stock)
Headers - Custom Tri "Y" configuration.
Brakes - Wilwood (New Front pads
Pedal assem - Tilton with multi place adjustment (really nice part)
Data - Aim MyChron 3 Gold XG Log with CDS GPS. 5 channel acquisition
Pro-Shift paddle shifter with "no lift shift" and auto blipper.
Ohlins Suspension all corners. These are top of the line Ex Indy Car shocks custom valved by Shock Shop. Extra Springs
Fire system - Spa
Momo steering Wheel
Accusump
8 Gallon Fuel bladder
Fuel lab regulator
Pick up pump and high pressure pump
Nine way adjustable suspension rockers
Torsen differential
Here is the original post:
http://www.apexspeed.com/forums/show...1-Sports-Racer
http://dsrforum.yuku.com/topic/10902...e#.WT3uYWjytPY Attached Thumbnails
