Page 1 of 2 12 LastLast
Results 1 to 40 of 64
    Northern NJ
    Default Wilwood LD20 Aluminum Replacement
    Just saw these listed on Pegasus.
    https://www.pegasusautoracing.com/pr...sp?RecID=27956
    I guess they are brand new? Anyone try them out? Actual weight?
    Paddock Lake WI
    Liked: 193
    Default Great price
    Wow, if they work well that is a great price! I just put AP's on my car or I would be all over these.
    mukwonago, wisconsin
    Liked: 96
    Probably flex like all there calipers do.
    jfb
  4. The following 5 users liked this post:
    Senior Member Bob Clark's Avatar
    Glendale, WI
    They are brand new. Weight is 2.30lbs without pads.
    I do not see flex being a problem. 4 big bolts holding it together.
    Bob
    Quote Originally Posted by Captain View Post
    Liked: 96
    Quote Originally Posted by Bob Clark View Post
    Bob
    4 bolts all lined up on the same bolt circle with almost no y-axis displacement. NOT a good design! Just my $0.02.
    jonh f
    PS
    If made to same dimensions as the steel version, it will be approx 1/3 as stiff as the modulus of aluminum is 1/3 that of steel.
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 601
    Default Calipers
    The AP calipers are a monoblock design, no bolts.
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
    Royal Oak, MI
    Liked: 270
    Love my aluminum APs!
    Vaughan Scott
    #77 ITB/HP Porsche 924
    #25 Hidari Firefly P2
    http://www.vaughanscott.com
    Liked: 1261
    Bob
    Are they making an LD19 replacement too?
    Anyone try these yet?
    Liked: 1261
    jonh f
    The AP LD19 units have the same bolts....
    Liked: 96
    The original LD19 was steel. As I said before, steel is 3 times as stiff as aluminum. If all dimensions are the same, a steel part will deflect 1/3 the amount that an aluminum part will with the same load. The bolt pattern is not a good design from a stiffness standpoint, but doing the same thing in aluminum is worse. Just my $0.02
    john f
  14. #11
    Liked: 1261
    I'm not referring to the original, I'm referring to the aluminum version of the LD19.....
    Clearly it is NOT monoblock...
    http://www.racing-stuff.com/AP_brake_caliper.htm
    https://www.apracing.com/product_det...p3696-6e0.aspx
    So why does AP bolt the aluminum LD19 and not the LD20 ?
  15. #12
    Liked: 1875
    john f
    The original LD19s were cast iron, not steel.
    The standard for caliper bolts is to place them on the same PCD and as close to the rotor clearance groove as possible so that the bolts offer their maximum stiffness value. All caliper manufactures have done this for decades.
  16. #13
    Liked: 96
    The modulus of steel is about 30x10^6, aluminum 10x10^6, and cast iron 13x10^6. I stand corrected concerning the stiffness of the
    aluminum vs IRON LD19. My mistake.
    I still say that the layout of the bolts is a poor design, as proved by mono-block designs. The bolted construction is more of a cost savings in manufacture than good engineering. Just my $0.02 on that note.
    jfb
  17. #14
    Liked: 1261
    Don't disagree. Monoblock would be better. But if AP bolts their aluminum LD19, I'm inclined to not discount the new wilwoods just because of bolts.
    Hopefully someone tests them soon...
    Vancouver BC
    Liked: 470
    One of the guys up here with the SCCBC has a set his fitting to his Tiga...
    ...he and Marty Knoll (MK Technologies) were involved in making these calipers happen.
    At least, that's my understanding.
  19. #16
    Royal Oak, MI
    Liked: 270
    Quote Originally Posted by 924RACR View Post
    FWIW, I have the alumiunum LD20 replacement front and the aluminium LD19 replacement in the rear (both from Keith)... still working through pad wear issues in the rear, but expected that and am making headway (through a combination of balance and cooling tweaks). Stiffness seems reasonable, though I'll admit I haven't done extensive back-to-back evaluation.
    Vaughan Scott
  20. #17
    Liked: 1875
    [QUOTE=john f;539257
    jfb[/QUOTE]
    No one is saying that a bolted design is better or equal to a monoblock.
    The layout of the bolts as close to the sweep of the underside of the bridge is absolutely the most efficient in putting the bolts into tension along with the usual bending. sorry, but that is an engineering fact.
  22. #18
    Arizona
    Liked: 323
    Back to what the Original Poster had asked. Does anyone have any experience or knowledge with these calipers?
  23. #19
    Connecticut
    Liked: 302
    Default Size
    I called Wilwood to try and get a cut sheet with dimensions on it but no luck. Told me they had not updated their web site is why it is not there but could not get one from them. AP's will not fit on my car wanted to see if they would before I bought a set. Maybe someone else will try them and let us know
  24. #20
    mission bc
    Default Wildwood LD20
    I bought a set of these and ran them on all four corners of my '96 VD FC on probably the track that is the hardest on brakes in North America (Mission). I was very satisfied. They worked as well as steel LD20's at less than 1/2 the weight.
  25. The following 2 users liked this post:
  26. #21
    Liked: 1261
    Quote Originally Posted by EACIII View Post
    i found info on there site when this thread started.....
    http://www.wilwood.com/Calipers/Cali...emno=120-14375
  27. #22
    Tacoma, Washington
    Liked: 210
    Never mind.
  28. #23
    Contributing Member cjsmith's Avatar
    Columbia SC
    Liked: 95
    Default LD20 Calipers
    I put a set of LD20s on the front of my 97 VD earlier this year at VIR, was having break issues with the AP calipers. I had to grind a little off the tabs to get them to fit to the front hubs. Other than that, no issues installing them. I was happy with the performance of the calipers on track. The weight between the new Wilwood and the AP I took off felt to be the same. In general, I am happy with the calipers, will order some LD19 for the back over the winter. I didn't replace all 4 at the time, I bought them from the Wilwood rep that was at the track that day. They only took cash as payment, I didn't have enough on hand to cover all 4 corners. Hope this helps.
  29. #24
    Paddock Lake WI
    Liked: 193
    Just fitted the LD20 version to the front and LD19s to rear of my 94 VD. Appear to be very good quality and very light.
  30. #25
    Senior Member xmazdatracy's Avatar
    behind you
    Liked: 130
    Quote Originally Posted by hdsporty1988 View Post
    Oh, nice catch. I did not see the 19's when I got the 20's. Looks like I have to play catch up .
  31. #26
    Paddock Lake WI
    Liked: 193
    Quote Originally Posted by xmazdatracy View Post
    I'm just trying to keep up with all the work you've done overthe winter!
  32. #27
    Liked: 3284
    IMO, as long as the bolts provide enough tension so that the caliper mating surfaces never separate from each other in any part of their contact surface, this bolted construction will be as stiff as or stiffer than a 1-piece caliper. That is because the steel bolts are stiffer than the aluminum that was drilled out of the bolt holes, so, if anything, a properly-designed, bolted 2-piece caliper can be stiffer than a 1-piece. So Richard, IMO, is being conservative in his 1st sentence above.
  34. #28
    Liked: 1261
    Looking to follow up on this thread.
    Any positive or negative experience with these calipers?
    Are you using the ST (Thermolock) coated version?
  35. #29
    De Pere, Wisconsin
    Liked: 31
    I am following up as well. Does anyone have insight on if aluminum calipers are legal for SCCA FF’s?
  36. #30
    Liked: 854
    Quote Originally Posted by 145inmy73 View Post
    They've been legal in SCCA FF for a number of years, maybe 5 or more years?
  37. #31
    De Pere, Wisconsin
    Liked: 31
    Thanks for the quick reply. I had read the rules a few times over the years but didn’t specially read that composite (aluminum) calipers were allowed. I run Formula Ford in VSCDA in the Midwest but we follow the SCCA rule book.
  38. #32
    Kansas City
    Liked: 110
    I put these on my Zetec last year and so far they have worked well for me. Pads wear evenly with no taper even after weekends at Road America and Gateway with extreme braking. I was reluctant to try them at first but happy with the results.
    I will add that I'm fairly easy on brakes and flip he pads between each weekend. After running a V you just get used to looking after your brakes.
  39. The following members LIKED this post:
  40. #33
    Connecticut
    Liked: 302
    Default Vintage rules
    You may want to check with your group as a lot of the vintage race groups do not allow the aluminum calipers.
    Ed
  41. #34
    Northern NJ
    I just got a set for Christmas. Its great when the family supports the addiction!
    The fit & finish is nice. Amazing light for someone use to iron calipers. Can't wait to try them!
  42. The following members LIKED this post:
  43. #35
    Arizona
    Liked: 323
    I have used these calipers on 3 different cars. I have been happy with them. The calipers ship with a reusable pin instead of split pins. The gauge of this pin is just a little larger than one style of LD19 pad I was using. Can't remember if it was the Hawks or Wilwood PolyMatrix pads. Anyway, simply running a drill bit through the eye on brake pad to open it up a little solves this. The other thing to note with these calipers is that the bleed screw is steel and what it screws into is brass. Don't overtighten the bleed screw. I have heard of people deforming the brass due to overtightening and then you can't get bleed screw to seal.
  44. #36
    Rocklin, CA
    Liked: 59
    Quote Originally Posted by Bill Johnson 42 View Post
    I have been using these for the past 3 years on my 2002 VD/Zetec with absolutely no problems. I switched to the Primus rotors in 2019 and those really chew up pads, I go through a set on the front in about 500 miles, about 750 miles on the rear. Important to flip pads as Bill says because the pad on the inlet side will wear a lot more if not swapped. I have used the Wilwood Polymatrix and PFC pads, not much difference in stopping power or feel, but the Wilwood pads squeal a lot when cold. I don't run the pads way down, I replace when about 1/3 of the friction material is left, to avoid putting a lot of heat into the caliper pistons.
  45. #37
    Lafayette INdiana
    Liked: 295
    I don't see how they can be put in bending in this application....looks like all tension to me.
  46. #38
    Lafayette INdiana
    Liked: 295
    This is better stated than my earlier comment.
  47. #39
    Liked: 1261
    Quote Originally Posted by Lyngengr View Post
    Did you use the ST version of the calipers?
  48. #40
    Burlington, WI
    Liked: 390
    That's funny.....i got a set for christmas too!
