Results 1 to 14 of 14
    Senior Member DK540's Avatar
    Virginia Beach, VA
    Liked: 83
    Default Screw-in wheel studs? 7/16-20?
    Many of us have odd ducks because previous owners have been, um, creative. Many of us don't know how odd until we tear something apart and try to replace or upgrade. Seems like almost no one sells screw-in wheel studs anymore! I have some spare "universal" hubs and the bolt circle I need to use takes a 7/16-20, screw-in wheel stud. That's 7/16-20 into the hub a half inch, and also 7/16-20 available for the wheel and lug nut, about 1-1/8" (at least 1", anyway). I've checked all the usual sources - Pegasus, McMaster, Summit, ARP, and several others. No dice.
    Anyone know of a source?
    Alternative, which is maybe lucky because the thread into the hub is 7/16-20, is to use long, full-thread bolts from McMaster. They certainly would not work themselves out!
    David
    Liked: 947
    Default Dorman
    I have done the full length threaded bolt through the back side of the front hubs on my Zink when I converted it from wheel bolts. It worked fine.
    Dorman offers some alternatives for studs.
    http://www.dormanproducts.com/gsearc...&q=stud+7%2F16
    Virginia Beach, VA
    Liked: 83
    Default Bolts, and Dorman
    Good info on both, Dan, thanks much.
    David
    New Jersey
    I did the same with my RF78, though McMaster Carr Grade 8 bolts. Though I cut the heads off, threaded them through the rear stub flange, and secured them with a Jetnut from the backside. This avoided having to disassemble the rear upright.
  9. #6
    Liked: 947
    Default One more idea
    near Athens, GA
    Liked: 837
    Google '7/16 racing wheel studs'. Quite a number of sources - including Summit.
    Virginia Beach, VA
    Liked: 83
    Default Good info
    Daryl - great source; I entered what I would like and we'll see what their quote is for a custom order
    Dan - worth considering... separate bolts or just cut a threaded rod. I like the idea of screwing through the hub and securing with a jet nut on the back (and some Loctite)
    Steve - did that exhaustively... almost all are press-in studs. I did not find the screw in I was looking for
    DK
    mukwonago, wisconsin
    Liked: 96
    Take the time to convert to press in studs. Problem then solved.
    jfb
    Liked: 947
    Quote Originally Posted by john f View Post
    jfb
    Press in studs are ideal. The hub holes must be bored and reamed to size before pressing in the studs. Otherwise they won't be straight and parallel.
    Regards,
    Dan
  14. #11
    Erie PA
    Liked: 31
    I don't deal much with fastener design, but what about a long set screw? Other choices available.
    https://www.mcmaster.com/#91375a690/=17w8qs7
    Ken Hoovler
  15. #12
    Liked: 96
    Regards,
    Dan
    Yes, that is correct, although if holes are bored to size, no reaming is required. As I originally said, take the time to DO IT RIGHT! Alot less trouble in the long run.
    jfb
  16. #13
    New Jersey
    I used bolts because I couldn't fine any threaded rod stronger than Grade 5.
    Edit: McMaster does list Grade 8 threaded rod now
    Quote Originally Posted by DK540 View Post
    DK
  17. #14
    Lots of import cars use screw in studs OEM instead of press-in splined studs.
    Personally I wouldn't use a piece of all thread no matter the rating simply because losing a wheel trying to save a buck seems penny wise and pound foolish.
