Odd that I did not find any results about the above subjects when I did a search for spark plugs... figured it would be covered ad nauseum, but maybe different search terms would help.
Anyhow, I see that Pegasus sells the Champion N6YC as the correct plug for a Club Ford with a Kent and a cast iron head. I've always ("always" qualifier - only two years racing) used the NGK BP8ES. Differences? Preferences? Reasoning? Temperature the same? Core the same?
And, the local Advance Auto only had resistor style NGK BP8ES when I went to buy 4 spares. Any less electricity to the spark with resistors? NGK says it only has additional ceramic, but I have read that some plugs use a slightly modified core to make them resistor plugs. Any concerns with NGK resistor plugs? Do they differ in how they became resistor plugs from other manufacturers?
And, finally, I think, with the Pertronix II, both coil and module, I can increase the gap on any plug by .005. Concur?
Thanks all in advance!
David
