Results 1 to 27 of 27
    colorado
    Default Keeping suspension arms unpainted raw steel
    I'm rebuilding my FB from the bottoms up and currently stripping the paint from all suspension arms. I'm thinking of leaving the suspension arms bare steel without any paint or powder coating. The car is always in dry weather and can keep an eye out for any surface rust or anything unusual.
    Any ill effects doing so? I have some stainless steel paint (Seymore MRO SS) I purchased if needed. But any overspray from brake cleaners or other chemicals will smudge the paint and remove it. I'd rather not deal with that if I dont have to.
    Thoughts?
    Arax
    Senior Member JLind's Avatar
    Brantford On Canada
    Liked: 53
    Nickel plate it and be done with it!
    James
    Morgantown, WV
    Liked: 131
    There is no direct detriment to bare steel.
    However, I have an awful hard time believing that it won't rust, regardless of your climate or how you store the car. If you use proper automotive paint brake clean or other normal chemicals should not damage it once cured.
    Woodstock, NY
    Liked: 81
    You might also try waxing the steel.
    I've used a butchers wax on many metals and it provides some protection without obscuring any of the surface.
    OC, CA
    Liked: 30
    Team Penske always used to, and may still, use bare steel wishbones, highly polished. It works in the maintenance cycle of an IndyCar, but will require very regular maintenance.
    Most other CART teams used black keyphos finish, Penske cars always had polished suspension. It was one thing that made Penske cars look good.
    Ian
    SoCal
    SoCal
    Liked: 102
    Do what the off road racers do. Clear furniture lacquer and a brush.
    Kaufman, TX
    Liked: 63
    You may want to look at Ceramic coating.
    This is a thin film coating that has a high corrosion resistance and great durability.
    www.RaceKote.com
    near Athens, GA
    Liked: 830
    Gun bluing is an easy to apply coating that should provide some minimal protection without much effort.
    Liked: 1477
    Unfortunately Steve, Bluing is just decorative. I've used it on steel parts before and I have an old blue shotgun. if you touch a blued surface you get a rusted fingerprint.
    It works on guns because they tend to be heavily oiled.
    San Jose? that's dry but what atmospheric moisture you have is salt fog. The most economical and durable method these days would be hand polishing up to about 1000 grit, and then electroless nickel. Not as bright as electroplated nickel but a lot more corrosion resistant.
    Liked: 1397
    Quote Originally Posted by socaljeff3798 View Post
    www.RaceKote.com
    Sorry to discourage this type of coating. It makes any repair to the part nearly impossible because removing the coating is marginal at best.
    Bare or nickel are the best. Down side of nickel is corrosion on the inside of the parts.
    colorado
    Great input, thanks guys! Sounds like I need to stick to my original plan and have these painted to play it safe. I don't want to spend any more money getting them coated professionally.
    The Seymour MRO paint I purchased (rattle can) claims to have some stainless steel particulates in it. It does appear that way when you're spraying with some fine pieces coming out.
    Londonderry, New Hampshire
    Liked: 101
    If you want the bare look, go with the clear lacquer as mentioned above. It makes crack check really easy. Another option from the offroaders is Steel-It. It'll give you the bare steel look with great corrosion resistance.
    colorado
    Can someone confirm that Penetrol will not come off with fuel or brake cleaner?
  15. #14
    Santa Fe, NM
    Default Steel black
    Watching NHRA today they showed the building of their cars using a substance called Steel black that they just rubbed on.
    Google shows:
    https://www.epi.com/black-oxide/stee...nsta-blak-333/
    Not sure if they referred to that specific product but seems simple and able fix scratches as they occur?
    Food for thought.
    Larry
  16. #15
    If you want to keep them bare, just apply WD frequently.
    PITA but it does work
  17. #16
    Vancouver, BC
    My own preference is for black oxide.
  18. #17
    Sagle, Idaho
    Liked: 180
    I wipe 3-in-one oil on our bare suspension parts.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  19. #18
    mukwonago, wisconsin
    Liked: 96
  20. #19
    Senior Member xmazdatracy's Avatar
    behind you
    Liked: 130
    Bikes come clear over bare steel quite a bit. Looks great in the beginning and after a few seasons starts to look horrible. I would go bare and keep it oiled, if anything starts to rust hit it with some ss pads and re-apply oil. looks cool and its light weight easy to check for cracks and repair is cheaper and quicker looks better after repairs... blah blah blah...
  21. #20
    Williamsport, PA
    Liked: 355
    There is the old Gibbs oil option. Lots of people say it works well on bare steel & magnesium, I want to try it on some things. A poor mans version is a ATF & Laquer Thinner mix that is out there too.
    http://www.roadsters.com/gibbs/
    https://www.thesamba.com/vw/forum/vi...528188&start=0
  22. #21
    Sagle, Idaho
    Liked: 180
    I noticed that we racers are last on the Gibb's list.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  23. #22
    Contributing Member jdp526's Avatar
    Texas
    Default Gibbs Protectant
    I am using the Gibbs oil on the magnesium and alum parts, like, steering rack, transaxle and covers. It does seem to last for many months before recoat is needed to slow oxidation of parts.
  24. #23
    Senior Member mmi16's Avatar
    Liked: 307
    Who repairs suspension arms? If they get damaged in any way, I no longer trust their integrity and onto the scrap heap they go!
  25. #24
    Sagle, Idaho
    Liked: 180
    A "desperate spare"
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  26. #25
    behind you
    Liked: 130
    Quote Originally Posted by mmi16 View Post
    please consider me next time you trow out something expensive out.
  27. #26
    Pittsburgh
    Liked: 296
    Quote Originally Posted by xmazdatracy View Post
    repair
    transitive verb
    1 a : to restore by replacing a part or putting together what is torn or broken : fix <repair a shoe>
    b : to restore to a sound or healthy state : renew <repair his strength>
    2 : to make good : compensate for : remedy <repair a gap in my reading>
    intransitive verb
    : to make repairs
    synonyms see mend
    Indeed, it seems repairs are adequately satisfactory. The issue of course is when the repair is either not adequate or not satisfactory or both. For the cars I have raced we have managed excel at adequate and satisfactory though.
  29. #27
    The picture in post #25 looks oh so much like DaveW thinking about what SCCA has done to formula car racing.
    About 18 years ago I remember one of our Apexspeeders finishing a regional race with a piece of concrete rebar welded down one leg of an A-arm to reinforce a "kink" in the aero tubing. and it wasn't me.
