Results 1 to 5 of 5
    Milan, MI
    Liked: 313
    Default Oil lines for front sump tanks
    What are people using for oil feed and return lines for oil tanks mounted in the nose of their cars?
    I could use lots of dash 10 Aeroquip but hard line would be lighter and I think cleaner.
    Is 5/8 id big enough when the oil is cold?
    Memphis, TN, USA
    Liked: 416
    What is the capacity of the pump? How far must it pull the oil?
    Charlie Warner
    fatto gatto racing
    los angeles
    Before I made a new tank for the rear, my Merlyn had the original front tank. It had two sections, one per side, of aluminum tube with a male -10 fitting welded in place at each end. These ran down the exterior of the body. Not super attractive but functional.
    Milan, MI
    Liked: 313
    That's what I had in mind, 3/4 od .06 wall aluminum or .03 wall steel with appropriate fittings. Just interested if others had issues.
    Liked: 942
    Quote Originally Posted by Dave Harmison View Post
    Mount the lines with soft mounts or cushioning.
