What are people using for oil feed and return lines for oil tanks mounted in the nose of their cars?
I could use lots of dash 10 Aeroquip but hard line would be lighter and I think cleaner.
Is 5/8 id big enough when the oil is cold?
What is the capacity of the pump? How far must it pull the oil?
Charlie Warner
fatto gatto racing
Before I made a new tank for the rear, my Merlyn had the original front tank. It had two sections, one per side, of aluminum tube with a male -10 fitting welded in place at each end. These ran down the exterior of the body. Not super attractive but functional.
That's what I had in mind, 3/4 od .06 wall aluminum or .03 wall steel with appropriate fittings. Just interested if others had issues.
