Results 1 to 5 of 5
Thread: Dash
    cambridge, massachusetts
    Default Dash
    Ideas for a Dash. What would be needed at a minimum, to keep the engine safe.
    RPM, Shift light, Oil pressure ?
    Will
    nevada
    Default dash
    WATER TEMP., shift light would be nice, oil temp , oil pres is useless at 15k revs even if you see it its done. best dash out there is mychron 5, get it from hyper racing $ 500
    Tomahawk WI.
    Default dash
    Will
    Give me a call.
    Rick
    Contributing Member jemartin144's Avatar
    chicago, illinois
    Absolute bare minimum these work. http://www.hyperracing.com/pages/pro...product=80-432
    has rpm, shift light, and water temp with warning light.
    Quote Originally Posted by rob66x View Post
    With the restrictors there is no sense it over 14,000 rpm, not that that make any difference. The key element in making the oil system live is to correctly get the oil level right and use a good oil pan. Then they live a long time. Calvin Stewart's Daytona winning car had 3 full seasons on the motor without any engine problems at all.
    He did have a battery failure at the Mid-Ohio Runoffs.
