Anyone have experience with using a MSD start retard system on a non MSD ignition system set a 35 degrees advance
I want to drop the advance to 15-20 degrees on start up only
This is for use with a Lucas ignition crank sensor, amplifier and coil
Do you have the Lucas cast aluminum box with hall effect pickup? Ours had the 50% retard built into it triggered with a momentary toggle switch.
our system uses a trailing edge trigger off the ex cam then a lucas amp AB14 then a lucas coil with no adjustment anywhere
the system is set at 35 advance at the trigger
