Results 1 to 23 of 23
Thread: CNC 603 rebuild
    Liked: 3787
    Default CNC 603 rebuild
    Sportsfans,
    I'm at wits end. (it was a short trip, i know...)
    I have four CNC 603 aluminum billet 4 piston calipers.
    They were rebuilt by a reputable racer a few years ago. Then put in a box.
    I can not get them to function. The pistons seem frozen in place. Some don't want to bleed.
    I have used the master cylinder for pressure as well as 120 psi of air pressure.
    At this point I'm ready to investigate sending them to a rebuilding service. But, once you look that up on the interweb there are thousands of options.
    I trust the recommendations of folks on this site.
    Any idea where to send them?
    Liked: 3787
    Might have found my own answer.
    CNC says they will rebuild them for $40 each plus parts.
    Plus shipping back and forth across the U.S. of A.
    Liked: 123
    while your answer is best, I was going to say that a grease gun can develop 10,000 psi of pressure, in an extremely controllable manner. I've used a grease gun with Marvel Mystery oil to free up stuff before.
    Sagle, Idaho
    Liked: 180
    I use a torch and apply just enough heat to get the seals to melt a little. $40 is pretty reasonable though.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
    Forum Advertiser bear01011's Avatar
    Middlefield, MA
    Liked: 94
    If it helps you any, I have an entire lot of CNC seals for sale:
    http://www.apexspeed.com/forums/showthread.php?t=76702
    VintageRaceCarSales.com
    Contact me to learn about our amazing vehicle consignment opportunities.
    Liked: 3292
    The seals have obviously either swelled or bonded themselves to the piston.
    I would suggest
    (1) fill the pistons with ice and heat the calipers (350F or so with a propane torch) to see if that amount of differential expansion will loosen the seals' grip and apply air pressure, etc., to try to move them.
    (2) If that doesn't help, use dry ice to shrink the aluminum, compressing the seals, then while still cold try air pressure, etc. to try to move the pistons while the seals' coefficient of friction is reduced by the cold.
    (3) If that still doesn't work, repeat # 1.
    If no success, then send them back for a rebuild.
    Londonderry, New Hampshire
    Liked: 101
    For $40 plus shipping, there is not question on the right answer.
    Liked: 3787
    My problem is that I'm the King o' Cheap. $200 is a fair price to have $2,200 worth of calipers. I'm afraid that once the calipers are in California they will say they new new pistons, new bleeders, etc. etc. and a $200 bill will jump to $400, for something i should be able to do myself. Plus the person that rebuilt them and put them in the box is somebody i trust, so I'm hoping it will just be a case of freeing them up.
    I'm going to continue the struggle all weekend, trying DaveW's ideas, if no solution by Monday, off they go to California.
    Late Braking Member
    Danville, California
    Liked: 217
    Default Try this tool?
    Caliper piston "wrench"
    I used one of these to free up and disassemble some old, ratty, stuck LD20s with low effort and no apparent damage.
    Liked: 3292
    Only disadvantage would be that if the pistons are fully submerged, there's no way to grab them.
    Sagle, Idaho
    Liked: 180
    Measure ID of pistons, turn round that's .010" smaller and about the same length as piston is deep, drill hole in center of flat end, tap hole to whatever size is appropriate, cut round in half down center of hole - make cut about .040 wide, insert halves in piston, screw in bolt that fits your slide hammer, pop pistons out.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
    Liked: 3292
    Measure ID of pistons, turn round that's 010" smaller and about the same length as piston is deep, drill hole in center of flat end, tap hole to whatever size is appropriate, cut round in half down center of hole - make cut about .040 wide, insert halves in piston, screw in bolt that fits your slide hammer, pop pistons out.
    Brilliant!
    San Diego,Ca
    Liked: 492
    Default Calipers
    CNC is a couple of blocks away. Chuck, the owner is a real straight up guy, and very proud of the things he has made.
    Roland Johnson
    San Diego, Ca
    Liked: 3787
    Roland, that is the kind of info I appreciate. Thanks!
    All the work HayesCages is laying out, while brillant, is beyond my shop's capabilities and harder for me to do than lay out the $200.
    OBTW, the pistons are flush with the inside edge of the caliper.
    Liked: 1486
    you guys missed the obvious:
    Froggie - what are you building.........
    Liked: 3787
    I am rigging up a single master cylinder on a pedal with 7' of steel braided -4 line.
    Mrs Frog can push the pedal and I wll hold the problem calipers on the shop floor.
    I'm thinking I can get a lot more than 120 psi out of that arrangement.
    Problem is if one piston moves, how to trap it until others move.
    $40 is starting to look like a deal. LOL
    Sagle, Idaho
    Liked: 180
    Klamp it Jed.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  19. #18
    Liked: 3787
    I'm glad they are only 4 piston calipers... I only have 3 clamps that are the correct size.
    We have worn shorts all season until this evening, then you let "weather" escape from Idaho into our neighborhood.
  20. #19
    Liked: 157
    Default Grease gun
    I back up Brian on this one. Brazed a few fittings together and used a grease gun. Works every time
  21. #20
    Liked: 141
    Default gun also
    Hard pipe direct, don't use a grease zerk or whip hose. Just leave the grease in, your going to clean it all up anyway.
  22. #21
    Pittsboro IN
    Liked: 281
    Put a piece of wood or plastic in place of where the rotor would be, thick enough that the pistons can't come all the way out of the bores. When the pistons release they will hit the wood and not damage the pistons
  23. #22
    Liked: 3787
    Success!!
    I had a text from Eric Langbein telling me that brake line pressures can be pretty high. Higher than 120lb. not to panic.
    And I knew these calipers had been rebuilt by a person I trust a lot.
    So... I rigged up a -4 line from a clutch master cylinder in a car in the shop out to the floor. Then by bleeding the cylinders and pumping the pedal i could 'creep' the pistons out basically one at a time. As one would start moving out i would put a clamp on it, then pump the pedal again. etc. etc.
    Was a big messy. But i got all 16 pistons out. Inspected. Put rubber grease on them and reinstalled. No heat. No ice. But about a pint of brake fluid used up.
    Thanks again to Apexspeed. Great input got me thinking.
    And now i own a complete set of replacement "O" rings. Thanks Kim Baker.
  25. #23
    Liked: 3292
    Super. Glad that worked.
