    Wisconsin
    Default Front sprocket lock washer
    After several gear changes this year my my front sprocket lock washer is wore out. I have checked with several Suzuki dealers but they don't list a splined washer, just a normal washer. Anyone know where I can find this?
    Sent from my SM-N920R6 using Tapatalk
    Senior Member David Locke's Avatar
    Indiana
    Liked: 175
    I've had three 2007-2008 Gixxers and none of them has had a splined washer.
    Hartford, WI
    Liked: 210
    Default <snort>
    Quote Originally Posted by David Locke View Post
    Lemme guess: you used a Locke washer.
    Indiana
    Liked: 175
    Quote Originally Posted by Jon Jeffords View Post
    Well played, sir! Actually, just a regular flat washer. I assume it's a Suzuki part, since they've all been identical.
    Somerset, Kentucky
    Liked: 126
    My old Yamahas (04-08) had those splined washers. Maybe the same?
    Alpine California
    Liked: 273
    Default I can solve this mystery
    Quote Originally Posted by openwheeler37 View Post
    That splined washer is not stock. Contact Richard Cotrill at Rilltech he sells them.
    We laser cut our own which have tabs that you bend over the nut. After 5 or 6 uses toss it out and put a new one on. Keeps the nut from ever loosening again.
    Gary Hickman
    Edge Engineering Inc
    FB #76
    Marietta,Ga.
    Liked: 61
    The Hayabusa doesn't use them, just a thick washer and a lock nut. I've been running them for over 10 years & they never get loose, no reason it should since the sprocket is splined.
    Scott Woodruff
    (former) F440/F5/FF/FC/FA
