Just repaired my cheap 10x10 popup for the, maybe, 4th time. Looking for a replacement 10x15 and found that the "heavy duty" models are 80lb or more. My current unit is 27 lb. What are the rest of you using? Any recommendations?
About 10 years ago I bought the expensive EZ Up model (Eclipse? Elite?) Mine is a 10'x20' and it is pretty heavy. In a pinch I can set it up by myself but not easily. On the plus side, it is still in pretty good shape after years of use at the track (and other places).
I'm a cheapskate with a small racing budget and the only reason I was able to pull off the top quality EZ-Up purchase was because my wife wanted something nice for an upcoming family reunion backyard party. :-)
Before the EZ-Up I used the conduit poles and tarp type awning. The EZ-Up is way nicer.
Check out Eurmax. They seam to have a good price range. Free shipping in the US and the quality looks pretty good??? I've been thinking about getting a couple 10X15's???
whatever you get, Please tie it down even if the forecast calls for no wind.
I am as cheap as they come (I race in F500 - duh), but I spent a little more on an EZ Up tent for one reason: replacement parts. Pop up tents will get damaged. It's a fact of life and racing. Writing off Walmart specials every time they get damaged will quickly cost more than buying 1 EZ Up and repairing it with readily available replacement parts.
I know there are other tent manufacturers that make pop ups that can be repaired, and sell repair parts, so EZ Up is not necessarily the only right answer.
Cory
I bring 5 gallon pails and fill with water so we don't have to carry the water weight when towing.
Ralph Z
1968 Alexis Mk14 Formula Ford
just want to remind anyone that may have forgotten, we get a 25% discount on EZ Ups with SCCA membership. I try to check before I get anything anymore, as I lose track of what some of the perks are.
http://www.scca.com/pages/member-benefits
The Karting community discovered Eurmax canopies a couple years ago, now that's what most use. I have a 10 x 20 pro model for $700, you can add the sides with a screen window and door for $200 more. Much heavier duty than the ez up. Comes with nice rolling bag too.
New popup did not fare well on its first outing. A brief up lift picked it and 3 10lb sand bags up and turned it over. One lower leg broke off(where it was tied to the trailer) The rest of it is ok The company says they have spare parts.
huh. which model did you get?
we are seriously considering one of the Eurmax Pro hex pole ones after my Ozark Trail one collapsed the first day I had it up.
I just received two 10X15 pro's. They look good out of the box?? I guess time will tell. nice hear that parts are available if needed.
I picked up a Quik Shade Commercial off Amazon for $130 to put next to my current EZup Express ii.
Although the headroom is nice, I don't like canopies without the cross bracing - the quick Shade is noticeably more flimsy than the EZ up. It also has plastic feet vs. the welded on metal ones of the EZup.
The next pop up I get will be an EZup pyramid or better. Its wort the cost.
Brandon L. #96 FF
I've had good luck with a brand called Undercover. Retail is $499 for a 10x20 and about $250 for a 10x10. Fairly sturdy aluminum design. They have a sandbag kit for about $69 that you can fill with up to 70# of sand each & they come with tiedowns.
You can get them direct from the factory with free ground shipping in the continental US, or hunt around the Internet (Amazon had the 10x20's at a deep discouint a year ago).
