Gday all, just putting out a dew feelers to see if anyone else has any knowledge of this issue, we are currently trying to fault find but just encase someone else has knowledge we dont it might be something simple, and better to ask..
Simply put we are loosing signal/data from the k line to the Evo 4 logger when the engine is started. (intermittent fault )
when the engine is off and the ignition is on we have a perfect signal and are receiving data and have a constant 7 volts from the k line.
however when the engine is started at a random point the data is lost. (the voltage drops to 0) we have tried a pull up resister in line and when the data drops we spike to 12 volts.
once the data is gone it dosnt come back until the engine is switched off.
We have checked connections as best we can, we have also replaced the GSXR ecu, we are going to try another K line to another Evo 4 logger next but are waiting to head up to the track for that.
So basically seeing if anyone else has had this problem or has some amazing suggestions? my next thought would be that maybe a sensor feeding the k line is tripping ? i would assume its not the TPS as the car runs fine, but maybe another???
Cheers Guys
