Results 1 to 8 of 8
    New Hampshire
    Default Track Bars/Push Rods/Trailing Arms/Leading Arms
    I was wondering if anyone here could help me out. I am rebuilding a formula vee chassis and I need some suspension components. Where do people usually get their threaded rods with heim joint ends for their pushrods, trailing arms, etc.? I will be needing a few for trailing arms and pushrods for my zero roll setup.
    Vancouver BC
    Liked: 471
    Assuming you're looking for the actual rod ends and not the components necessary to fabricate a pushrod:
    McMaster-Carr
    Aircraft Spruce
    Those are two sources I've used.
    And of course, Pegasus Auto Racing Supplies
    And if it is things like the threaded tube ends that you use to fabricate a pushrod, etc. ...
    ...Pegasus also has those
    Hope this helps.
    Liked: 304
    bcvinar,
    there are quite a few FV suppliers that may have what you need and can recommend the correct components.
    One is Quixote Racing - Dietmar Bauerle
    I know he keeps rod ends of high quality and reasonable price.
    You can call him anytime, at least within his normal working hours. On the west coast so 3 hours behind us. UPS flat rate means shipping is cheap.
    http://www.quixoteracing.com/
    619-561-7774
    New Hampshire
    Thanks guys. The item I was looking for was the swedged tube or tie rod tubing. I knew about the actual heim joints, but was more concerned about the actual arms. I had heard of McMaster Carr but found it rather difficult to navigate. There was also Speedway Motors which I had found some in 3/4" and 5/8" thread and of various lengths.
    Liked: 304
    "The item I was looking for was the swedged tube or tie rod tubing"
    Keep in mind that you do not have to use swedged tubing. Straight tubing will work just fine and you can get tube ends to weld in with the thread you need, left and right.
    New Hampshire
    I did not think of that BLS. I appreciate the pointer!
    Liked: 304
    I used CM tubing. Easy for me as Stock Car steel is 20 minutes from my house and they have the best prices for steel tubing I have found. They ship, so no problem.
    http://www.stockcarsteel.com/
    Duncannon, PA
    Liked: 300
    For push rods/rear suspension and tie rods/front steering I have been making them from solid 6061 aluminum rod and drill the ends and tape them out for either left or right threads to attach to the rod ends. $25 for tie rods and $30 for push rods made to your specs as far as length and rod end size. Tie rods are 5/8" OD and push rods are 3/4" OD but I can pretty much do what you want by obtaining whatever size material you need.
    Ed
