Originally Posted by
Keith Robinson
So, a little late with the update!
The noisy transmission ran 6 or 7 races last year, worked fine except other competitors complained about the noise!
Took it apart and found nothing obviously wrong but decided to replace the pinion bearings anyway while I had it apart. Ring and pinion wear wasn't too back, backlash still within spec (.010"). Wear pattern looked OK, I checked with Prussian orange stuff!
However!
Upon re-assembly I have discovered there are two bearings available and the one I bought from the VW specialist (he said he had sold two to another local rebuilder/racer) has a larger rear tapered bearing and requires modification to the reverse gear hub! Of course I found this out after having re-installed the transmission into the car.
Pegasus does make reference to the fact that the bearing they sell fits like the original but I was going to save money, rrright. Going
to miss the next race instead, grrrrgh!!!
