Just thought I'd post a simple way I found to mount front and rear brake pressure sensors directly to Girling master cylinders. This application is on an 88 Reynard.
By using two Russell Brake Switch Banjo Bolt Fittings (1/8" NPT Fem. x 3/8" -24) and attaching them to the banjo fittings going into the master cylinders you avoid using the typical -3AN 'Tee' brake line connector splice and adding 4 potential fail points in your brake system. I used the Aim PRS-839 brake pressure sensor and it fit perfectly.
Bob
