All 6? Only 3?
All 6? Only 3?
3 in the front 6 in the rear
Like Mr. Anderson said. 3 in front, 6 rear.
My new car has 3 per, all the way around. Thus the reason I ask.
Frank I would run 6 is the rear and not worry about the extra weight. It may save you a DNF
Cars came new with 6 in the rear 3 in the front.
The more pins you run, the longer your wheel centers will last. 6 in the rear and 6 in the front is your best bet.
If you are only running 3 pins, and one happens to break, and you don't catch it in time, you will be running on only 2 secure pins, which will increase the likely hood of failure exponentially.
That being said, I would say that i see about a 50/50% of 3+3 and 3+6 out there.
Moses
