I need to install new harnesses and was wondering what others are using in the super tight confines of a vee cockpit. Thanks!
Bob,
Racequip, camlock pull up style lap belts. Great product, customer service and re-webbing at a reasonable cost.
Tom
The cars I have driven and those in the shop now, all have lap belts that use one method or another to fix their length. They have little room for lap adjusters.
Our choice is Willans.
I run the Formula belts from OMP. They are HANS shoulder straps, bolt in, pull up lap belt, camlock belts. Perfect. Send a note to: dan@425motorsports.com and he can ship them. Very good belts.
Stephen Saslow
+1 for the OMP belts. I just bought a set for my Crossle.
http://www.ompracing.it/en_gb/car-ka...-sl-44845.html
something else to keep in mind, unless it changed & I missed it, is that FIA belts are valid longer than "regular" belts, so you don't have to replace them as often. and definitely get HANS belts. the narrower shoulder straps are really handy.
I use Schroth, personally. they had all the features I wanted & I found them more inexpensive than other brands.
Thanks for the replies. I ended up going with the G Force 3" cam lock with pull up lap belt. They are very adjustable and with some preliminary fitting, it seems they will work well. They also have the click-in sub belts which are much easier than the lace and loop ones I have now. I'm using the Necks Gen helmet restraint that accommodates the 3" belts so I should be good to go. Thanks again!
SCCA no longer requires SFI belts to be replaced every two years. It is now 5 years, same as FIA.
Ah, good. I haven't had to replace mine since I bought FIA belts, but I think I'm on my last year with them. Nice to see some common sense on doing that.
I went with simpson formula belts. Seems to do the job with flexibilty to cinch up each belt. Their customer service is top notch if you wanted to mod the belts, i.e. shorten and resew, to your car specs.
Something to consider, get a set of 'pull up' lap belts and only use one adjuster. One side can be set up at the correct fixed length then the other side is used to cinch it down tight. That can get you a little more room that a set with 2 adjusters.
-John Allen
Tacoma, WA
'82 Royale RP31M
That's exactly what I was thinking while I was in the car test fitting the new set. I was able to adjust the one side to a fixed length and cinch down the other side and that worked well. Neither adjuster is in the way. In any case, getting properly belted in is definitely a challenge in these super tight cockpits.
Great that it works and you have enough room for both adjusters. I was trying to suggest one side of the laps not having any adjuster - fixed length -and only one side with a pull up.
I ended up going the full fixed belt route. There was NO way I could pull up the adjusters in my car (very tight in the shoulder area) and there may be a time I won't have a crew. Once you get the length right (with the help of another person), it only takes a little practice to click yourself in on your own (deep exhale and click!)
Of course the best way is to get a cute grid girl crew member to help buckle you up (my wife might have an issue with that!)
-John Allen
Tacoma, WA
'82 Royale RP31M
I have mine like that. On one side of the lap belt I have a fixed belt, and on the other side I have a pull up adjuster. Works great within the confines for me. John
