In specific, my steering arms use a 1/4" bore, 3/8" shank rod end at the steering rack end.
Anyone know where to ask for such?
Alan,
Averill and Pegasus carry oversize shank rod ends, but double check dimensions. Usually a 3/8x24 shank will have a 5/16 bore.
Another alternative would be to press a bushing into the bore to size it to what you need.
Good luck.
Believe me: I've checked. In fact, I just checked again. It's a 1/4" bore with a 3/8" shank
But I can't press a bushing into a bore to make it larger in diameter, Dan. I wish I could.Another alternative would be to press a bushing into the bore to size it to what you need.
Thanks, but I think I now know what I've got and what I need.Good luck.
A closer look shows that the ball has been ground/file/machined on both mounting faces. I just check the Aurora Bearing website, and what I've got is an HXAM-4 (or equivalent); a high misalignment rod end that's been modified to reduce the ball width from 0.593" to 7/16". Everything else matches up: head thickness, overall length, etc.
Mystery solved!
Can't see the forest through the trees. Happens to us all sometimes.
