First off, new owner, I have a lot of questions. So, pardon me if I seem a little too enthusiastic.
Now, back on topic.
What are the stock ratios in the box for a normal FM? Is there a standard?
Now, back on topic.
According to the Formula Mazda rules found in the GCR (section 9.1.1.E.15)
15. Gearbox
A. All cars shall be equipped with some combination of the following
gears:
Mark5, or Mark8 Series Gears 15:36 – 15:30 – 15:25 – 17:34 –
19:32 – 18:25 – 21:29 – 17:23 – 22:30 – 24:27 – 19:23 – 23:28
– 25:26 – 26:25 – or 26:26 Webster; 24:24 Hewland
B. Additional approved gear ratios may be added by the manufacturer
with SCCA Club Racing authorization.
C. Reverse shall be installed and in workable condition.
D. Gearbox rear covers may be modified to permit installation of longer
shift finger shafts.
E. Transmission drain plugs shall be safety wired.
F. Shift rail stops may be added to transmission shift mechanism.
You can download the GCR from this page:
http://www.scca.com/pages/cars-and-rules
Thanks David!
Frank, keep in mind that you are not running by the FM rule book so you don't have to run those gears. You have a few more options with that in mind.
If you haven't already learned how to tear down a gearbox you should before you go out to the track. You will see that the gears all have engraved numbers on them indicating what they are.
there might be some videos but I don't recall seeing any. A kind fellow named Brad Drew from So Cal taught us at the track out of necessity. There are tips/tricks to it but the basics are pretty easy. When I first started I went through a set of dogrings per weekend. Now it is every 3 weekends lol. You will need to know how to change gears for tracks with long straights, etc. If you find any video's you should post them for the next guy. Hell, maybe I'll take one and put it up on here for everyone. I can't do it but everyone else on my team can. I'm afraid if I learn they will make me do it myself moving forward!
Dan
Watched that earlier! Does it apply since it's a MK8, and not a MK9?
I also saw THIS one, on how to reassemble a box with 1 hand:
https://www.youtube.com/watch?v=xU6eC8fDMvk
I will let somebody more familiar with FM internals comment, as to not lead you astray.
But, here's what I found with a cursory google search:
http://www.taylor-race.com/pdf/ACF14E2.pdf
And wonder about this statement: MK8/MK9 (if using “M” type MK5 gearsets 240 HP and Quaife or Salisbury Differential)
Can someone tell me what an "M type" gearset is?
http://hewlandclassic.com/assets/manuals/mk9.pdf
And HERE is the yellow covered "Maintenance and overhaul manual" (This is for sale online in several places!)
http://www.willrace.com/Technical-Do...ies-Manual.pdf
Frank
Call up Mel and ask what he runs at Portland, open the box and see what is in it, or just take it out and see if you run out of revs mate.
Are you planning to race or is it a track day car?
