Results 1 to 10 of 10
    Midland, MI
    Default 2015 Solo Nationals : CM
    2015 SCCA Solo National CM Entry (19)
    4 Vernon Maxey 2004 Solo Vee LynxB
    14 Joshua Parker 1985 Reynard 85F
    21 Robert Qualkinbu 1990 Adams Aero Solo
    31 Brent Cary 1988 Reynard FF1600
    42 Collin Eric Moore BobsyVanguard SoloVee
    50 John Engstrom 1985 Swift DB1
    65 John Powell 1985 Reynard 85F
    70 Benjamin T Cort 1982 Reynard FF1600
    73 Charlie Davis 1985 Reynard 85F
    83 Ray Thomas 1983 Reynard Formula Ford
    87 Brandon Lavender 1985 Van Diemen RF85
    91 Bruce Faucett 1984 Van Diemen RF-84
    94 Eric Clements 1994 Van Diemen RF-94
    96 David Fauth 1995 Van Diemen RF-95
    150 Chris Pruett 1985 Swift DB1
    170 Andrew Howe 1982 Reynard FF1600
    191 Colin Faucett 1984 Van Diemen RF-84
    194 Jonathan Clements 1994 Van Diemen RF-94
    196 Barry Ott 1995 Van Diemen RF-95
    Solo Nationals competition takes place at Lincoln Airpark in Lincoln, NE from Tue, Sept 8th until Fri, Sept 11th. CM runs the 5th heat on Thr/Fri. Live Timing available via http://sololive.scca.com/
    Chris Pruett
    Swift DB1
    Contributing Member mblanc's Avatar
    swisstown.com
    Liked: 42
    Can you (or somebody) go ahead and rearrange that list in your guess for the final finishing order?
    Or at least top 5 or so ?
    FFCoalition.com
    Marc Blanc
    San Jose Ca
    Hey just wait and listen on solo live and cheer on your favorite driver
    Ben
    Midland, MI
    Default Via SportsCar...
    Quote Originally Posted by mblanc View Post
    Attached is an extract from Sept/15 SportsCar's "Who will Win" the Solo Nationals article. Other names to watch beyond those mentioned in the extract include Fauth/Ott in the RF-95/Fit as well as Parker in the 85F/Ford.
    As for picking a finishing order, I believe either Brandon or Jonathan will take the top spot but it would not surprise me if one of the others mentioned (or someone else) won.
    Honestly, you can randomly choose the noted names for finishing order and be closer to any prediction I can make!
    Chris Pruett
    Swift DB1
    Midland, MI
    Default In Ladies...
    The above said, I will make a pick for CML: Krystal Lavender
    Chris Pruett
    Swift DB1
    Elizabeth, CO
    Liked: 74
    Quote Originally Posted by -pru- View Post
    That's a great picture! It's hard not to pick a Lavender double.
    Midland, MI
    Default Who Will Win : CM/CML?
    "Who Will Win?" polls now available on SCCA.com :
    CM : http://www.scca.com/polls/1964616
    CML : http://www.scca.com/polls/1964618
    Chris Pruett
    Swift DB1
    Michigan
    Liked: 237
    And if PRU finds the keys he might be in the running too!
    Midland, MI
    Default Yep...
    Quote Originally Posted by Gordy View Post
    Thanks dude!
    As I noted elsewhere, more likely puzzled at all of the gravel, grass, and rubber that ends up in the seat. It always amazes me how much "crap" accumulates inside the car given the short amount of time we run these things...
    Chris Pruett
    Swift DB1
    Midland, MI
    Default 2015 CM/CML Champs!
    Josh Parker takes the 2015 CM win!
    Krystal Lavender takes the 2015 CML win!
    Chris Pruett
    Swift DB1
