Results 1 to 38 of 38
    Pittsburgh
    Liked: 89
    Default E250 as tow vehicle?
    Hello all,
    There are several used E250 vans for sale in my area. Approximately 10-12,000 miles for appx. $20-22K.
    I was thinking of getting a half or 3/4 ton truck to use as a DD and tow vehicle but I don't really want to trade my 3-series away, it's so nice to drive.
    I have places to keep it, so storage is no problem, but how do they tow and are they better or worst then a truck to go to the track with. The trailer will be a standard 20 box trailer. Total weight of trailer would be 5-6000 lbs.
    Any experiences would be appreciated!
    Tempe, AZ
    Go for it.
    But why such a heavy trailer?
    Caldwell D9B - Sold
    Contributing Member Ken Lawrence's Avatar
    Tulsa, OK
    Liked: 53
    I have used a '83 and a '97 E250 for years, no problems and lots of room for gear. Currently using a Nissan NV3500, best yet.
    Rhode Island
    Default E350
    Towing with an E350. Tows but fuel mileage is 10 to 14 depending on hi speed runs
    Liked: 292
    WTF is an E350? a Merc???
    one ton ford full size van.
    Also a merc, but would not use one to tow with
    Liked: 292
    anybody ever tow a small bore formula car on an open trailer with a Chevy Malibu Max?
    I have a '08 E350, which has been fantastic.
    My 20' box trailer weighed ~5400 lbs loaded with everything including Zuma scooter.
    I kept tongue weight at 600 lb. by planning load placement.
    Rhode Island
    Default towing
    In days gone by i towed a caldwell D9 on a light weight trailer behind a VW Rabbit. No problems
    Member H_Mode's Avatar
    NH
    Long time ago, F440 behind a 83 Malibu. Two wheel open trailer, back seat full of gear.
    Did blow a upper radiator hose on a long hill and have an engine fire tho'... That is when I learned that anti freeze can burn.
    Member Sully's Avatar
    New Boston, MI
    Are we talking Diesel or Gas engines in these E250 / E350's?
    Nick Sullivan
    F5 #92
    '97 Red Devil T-27
    facebook.com/SullySpeedShop twitter.com/SullysSpeedShop
    Rhode Island
    Default fuel type
    Gas
    Hoschton, GA
    Liked: 757
    I use an E350 7.3ltr Diesel passenger van and can't imagine using anything else. Good (ish) fuel economy and pulls like a train.
    Senior Member beachguy12's Avatar
    CA
    Liked: 29
    I used an Acura TL for a long time to tow a Crossle 32 over the Grapevine on I5 in CA. Now I use the small Hyundai Santa Fe. No problems with either.
  17. #15
    Liked: 1262
    Quote Originally Posted by beachguy12 View Post
    Is there room for all your "stuff"
    I'm towing my FC with a Tundra on an open trailer and I just don't have enough room (the bed has a flat lid).....
  18. #16
    My E350 is a gasser. It was a 12 passenger rental. I bought it used with 15K miles for a song. (like $15k) Now have 100,000 with no service issues. I drive it daily with my business trailer behind it. So those are 100,000 towing miles.
    Without the all the rear seats it is very spacious. Because it was a passenger model the rear walls/ceiling are upholstered, with overhead lighting, and it has a rear A/C unit. Because it has dark tinted windows all around it doesn't look like a trade van.
    The load range E tires are another plus. And the rear end is for a real truck not your neighbors dinky F150.
    Everything in a pickup either gets wet or stolen...
  19. #17
    Liked: 292
    HOLY COW over the Grapvine....i am impressed!
  20. #18
    Banned
    Liked: 1116
    This topic is akin to bench racin' mixed in with so much subjectivity as to what's acceptable and/or required.
    Cajon/Grapevine/Baker and Cuesta grades are all large grades that folks towing into/out of southern California to tracks in our area have to deal with.
    There are vehicles used as tow vehicles that can't get up those grades at the speed limit when they aren't towing anything. 20MPH below speed limit while towing is acceptable to some, while others aren't okay if they can't do the speed limit up every grade in the Country.
    A 3/4 ton gasser is going to be well within it's maximum tow rating with a trailer such as you are contemplating. Engine/trans/rear end is going to determine just how capable it is. Tires and cooling system is going to determine how stress free it is.
    Vans have some advantages (as mentioned above) but they also have disadvantages. You and those traveling with you okay with the smells and noise of everything in that van with you as you travel to/from the track? In an accident I'd much rather have a bunch of stuff in the bed of the truck than the rear of the van I'm driving.
  21. #19
    Liked: 1262
    Just assign the job of catching that floor jack to someone not high on your list...
  22. #20
    Santa Rosa, CA
    Liked: 268
    Default towing
    Not sure why you would need an E250 or 350 to tow a trailer with GW of 5-6000 lbs. I have towed for years with a F150 with both the 4.6 and 5.4 V8 with a 20 ft enclosed trailer with a GW of about 5000 lbs with F1 car and spares,tools at full speed limits ( and above ) up and down the Sierras, Rockies and Cascades as well as cross country. The 4.6 is slightly limited in the mountains but the 5.4 has no problems at all. Averages about 11-12 MPG towing.
  23. #21
  24. #22
    Banned
    Liked: 1116
    Not sure why you would need an E250 or 350 to tow a trailer with GW of 5-6000 lbs..
    It's not a need. It's a safety margin. The less it's working the longer it will last.
  25. #23
    Santa Rosa, CA
    Liked: 268
    Default towing
    Daryl, I've towed over 200,000 miles with these combinations with no issues.
  26. #24
    Pittsburgh
    Liked: 89
    The vans in question all have the 4.6 engine which is less then ideal but serviceable.
    Looks like I'm going to go with a 24 foot trailer, I found a great deal on a 2 year old race trailer that is all set up with tire racks, workbench, cabinets and an 8000 pound whinch for only a few bucks more then a new 20x8.
    Thanks for all the feedback.
  27. #25
    Banned
    Liked: 1116
    Glad to hear you've had good fortune. I don't know how many different vehicles it took to accumulate those 200K mi. I am confident you didn't do it all with the same 1/2 ton truck.
    I towed an E-Prod Rx7 on an open trailer (16 x7) from Santa Barbara to Laguna Seca and back with a F150 with 5.0----never again. I felt like Hiro Matsu****a out there on the 101.
    I have towed with much, much better suited vehicles. Each of us has our own comfort level of the performance/safety we expect from our tow vehicles. I towed a 4000# trailer with a 20,500# RV on a F550 chassis. It didn't get up any hills in a hurry but I had plenty of brake, suspension, tire and chassis to handle it. I'll save the racing for the track.
  28. #26
    I worked for a guy who bought a new E350 ambulance-ready van to use as a tow vehicle for his fully loaded 24 ft trailer back in about 1990. We brought everything including full upper and lower roller tool box, two full size N2 bottles, 55 gallon drum of fuel, a press, etc. It was ok on the straights but the thing got 6-8 mpg going 70 mph with the gas big block. We went up and down the west coast and to the Runoffs in Road Atlanta in 90 or 91.
    Based on that experience, when I could afford a new tow vehicle to replace my 10 year old 4 cylinder Ranger, I bought a 2003 F350 diesel crew cab long bed with a Manual trans. I still have it, almost 80k miles, and it'll tow 70 mph easily without a weight distribution hitch but as fast as I want with one. When I drove from CA to TN, I doubt that I spent 15% of the drive under 80 mph.
    IOW, it you're gonna get a tow vehicle, get the best you can afford. Get a used one if it allows you to keep a nice daily driver!
  29. The following 2 users liked this post:
  30. #27
    Pittsburgh
    Liked: 89
    I picked up a 2014 E350 for a decent price with 33k on it. It's a passenger model, with dual a/c and lights and the bigger 5.4 motor. Should be a safe combo with lots of room for people and gear.
    Any thoughts on the need for a weight distributing hitch?
  32. #28
    Necessary.
  33. #29
    Santa Rosa, CA
    Liked: 268
    Default towing vehicle
    Daryl,
    You are right it took two vehicles, a 1999 F150 4.6 ltr and a 2009 with the 5.4 ltr to make those 200,000 miles towing the same car & 20' enclosed trailer @ 5000 lbs. But if it makes you feel better maybe you should get an 18 wheeler to tow the RX7. By the way the 2009 now has 132,000 on and has back and forth to RA from the West Coast four times.
  34. #30
    Banned
    Liked: 1116
    Nah, that would be overkill....
    My F550 based RV with a V10 got the job done with enough safety margin for me. Not winning any drag races or hill climbs with it.
  35. #31
    Contributing Member Kazis31's Avatar
    Circuito Do Sol Portugal
    Liked: 384
    Mercedes Benz 2500 Sprinter .Turbo diesel
    Tows up to 5000lbs.
    22-24 MPG
    18 towing.
    will need lighter trailer .......
    Maris Kazia ,CEO
    EuroKraft Inc Racing
    Circuito do Sol
    2014 Radical SR 3 RSX, 2x Tatuus FA 01
    BMW HP2 .BMW K1200 R.Porsche 996 Carerra 4s
  36. #32
    Liked: 227
    Daryl,
    Previously in this thread, you posted a link to a review of a 2011 F150 with the 5.0 engine. The review praised the truck's ability to tow a 9k pound trailer on hills and flat roads. Do you disagree with the review or was your experience with an older 5.0 F150?
    Cory
  37. #33
    Contributing Member Chris Elwell's Avatar
    Owensboro, KY
    Liked: 58
    I tow a FV with a 2008 Volkswagen GTI. No problems at all and 23-24 mpg while towing.
  38. #34
    Banned
    Liked: 1116
    Quote Originally Posted by cory mcleod View Post
    Daryl,
    Cory
    My personal towing experience with a 1/2 ton, gas, small block (5.0) was with a '91 F150. It sucked towing 4000# up the Cuesta Grade to Laguna Seca. Not only was HP/TQ lacking, 1/2 ton trucks generally aren't/weren't geared low enough. Brakes were inadequately sized as is the anti-roll bar.
    I don't disagree with the article at all. How could I? I referenced it to illustrate the relative strengths and weaknesses and the performance standard. High praise for a vehicle, with foot to the wood for 3 miles, that barely averages 60mph because that's better than the competition. Some of the grades being mentioned in this thread are longer and steeper than the portion of the grade used in the test. Granted we are talking about 5K trailer not 9K, but don't expect to "hardly know it's back there". If anybody expects to get a half ton truck and tow all over the western mountain ranges at the speed limit, they need to be aware just how hard they'll be flogging that thing and how likely/unlikely that is to happen.
    Bench racing, fishing tales, and towing stories usually get embellished just a bit.
  39. #35
    Liked: 227
    Thanks. That's helpful. This thread is interesting to me, because I will be replacing my V10 Excursion in the next year, and would rather get a half ton truck if I absolutely don't need a 3/4 ton.
    Part of my issue is that I don't know exactly what my trailer weighs fully loaded. I think it's 6,000 - 6,500. Where do people get their trailers weighed when they're loaded, or are most people just trying to add up the weight of the contents and add it to the weight of the empty trailer?
    Cory
  40. #36
    Banned
    Liked: 1116
    Cory
    http://www.publicscaleslocator.com/charlotte-nc.html
    3 easy-ish ways to do it:
    Just put trailer axles on scale and add 10% for tongue weight.
    Put the whole rig on the scale and then come back and weigh just your tow vehicle and do the math.
    Put the trailer axles and tongue jack on the scale and raise trailer until tow vehicle hitch is at the same exact height it is when the trailer is not connected.
  41. #37
    Erie PA
    Liked: 31
    The local scrap yard or grain elevator will have a truck scale plenty big enough to weigh your trailer or entire rig. Should only cost a few bucks for a slip, or nothing if you know the right guy.
    Ken Hoovler
  42. #38
    Liked: 227
    Awesome! Thank you Daryl and Ken.
