Results 1 to 8 of 8
    Contributing Member CJD's Avatar
    Winter Springs, FL
    Default RF 96 Radiator Bleed Tubes
    My RF 96 has the two plastic radiator bleed tubes and I want to replace them with -3 braided line. Does anyone know what the thread size for the swirl pot and the radiators are? I'm not sure if they are NPT or SAE. I want to make sure I get the right fittings. Thanks for any help.
    Senior Member suzrm121's Avatar
    Bellingham, WA
    Liked: 6
    Default I think
    I think they are BSP (at least mine are)
    Winter Springs, FL
    Sizrm121, thanks I hadn'd considered that.
    Liked: 923
    NPT will have a visible taper.
    BSP thread dimensions can be found in the Pegasus catalog as well as NPT
    CJD
    Winter Springs, FL
    Default Van Diemen Radiator bleed tubes
    I just had Pegasus look over my radiator bleed tubes and they can identify the fittings that attach to the swirl pot and they are indeed BSP. However they can't identify the fittings that attach to the radiator and none of the fittings they have match. Anyone out there know what these fitting are? I'm completely baffled with something that should be so simple. Thanks for any and all recommendations.
    Liked: 1262
    Picture?
    Winter Springs, FL
    Default Radiator Bleed Tubes
    I sent the two bleed tubes to Pegasus and should have them back shortly. I'll post some photos once I have them.
    Winter Springs, FL
    Default Radiator bleed tubes RF 96 Van Diemen FC
    Alcon, FYI. I just determined my radiators have metric threads for the bleed tubes and the swirl pot uses BSP. Wanted to pass on to the group. Also a shout out to Pat Prince for his recommendations..
