Update 8/8/2015: Sold! Thanks ApexSpeed!
Update 7/30/2015: I have taken a deposit on the whole package. I will update the post again once the sale has completed.
1986 Swift DB-1 Chassis 86-002 4130 Chrome moly
Sorry, I had to change plans so I won't make Laguna with the car... Sorry if this interrupts anyone's plans. The car will "NOT" be at Laguna Seca July 24th and it is still available.
If your in the market for a DB-1 perhaps this is the one for you! The car has had many updates over the time I have owned it and has seen relatively few races.
$17,500 for the DB-1 with listed spares.
$23,500 for package with the E350 to take it in the "To-Go" Box Van
Ken Glasser
310-947-2411
Bodywork is modified freshly painted by Tom Irwin- Includes Spare nose
Chassis Upgrades:
Revised Pickup Points on Chassis – Victor Hertfelder
Sleeved uprights (Fast Forward) Prevents wallowing of wheel bearing in upright.
Front Upright bottom studs replaced with stronger Protech parts –Ray Germaine
Lightened Hub design (front and rear)
Protech bell cranks & sway bars– Ray Germaine
Protech a-arms– Ray Germaine
Chassis braces added modified for additional room in cockpit
Kevlar body panels
Tubular crush box
Modified Pedal Pickups for shorter driver
Modified belt anchor points for HANS
Cockpit adjustable rear sway bar
Cockpit adjustable brake bias
Rear Suspension Shear Plates – Upgraded to 3/8in from original 1/4in
Engine cylinder head steel mounting braces
Steering Rack bushings replaced Protech –Ray Germaine
Original Fox shocks were modified to simulate Penske – Joe Stimola
Fox Shocks
Double Adjustable – Stimola Modified
0513191-SRP LF/RF
0513190-SRP LR/RR
Fuel Cell was replaced
Fire Bottle is NEW...just installed
Bell Housing/Oil Tank/Suspension Pickup Module has been repaired at lower pickup point – Victor Hertfelder
Motor:
Arnie Loyning – Dyno Sheet Included
Header (Art Smith)
Spare Head - Farley
Crank
2 sets Panasports (Graphite & Gold)
Transmission
Transmission modifications & Lightened Diff (Lee Williams)[/SIZE]
Spare Clutch
Spare Prepped Head
Spare Carb Prepped - Ivey
Wheels 2 sets Panasport 4 lug One set Grey, One set Gold
Gears – 20+ Sets …need to update list
Chassis Stand
Easy Up
Other spares and bits...
Race Hauler:
1995 Ford E-350 Box Van 7.5L Gas Engine
Picture below is of a similar van but mine has the bigger engine!
Other upgrades include Heavy Duty Rear Springs – PTO Gear
Hotchkis Front and Rear Swaybars
Maintenance including servicing heads, radiator rebuild and new water pump
The van is set up with a winch and ramps to load and unload the car.
Registration current through August
Documented log book history to be added later...
