Results 1 to 21 of 21
    Farmington Hills, MI USA
    Liked: 52
    For Sale Formula Mazda project for sale - SOLD
    Here's what I can tell you about the car. I bought it from Valley in 93, believe it was built around 88 (could have been earlier). It was the first FM east of the Mississippi, back when FMs were classified as FCs and only allowed to run regionals in SCCA. Mike Sheehan was the previous owner. It is a Russell shear plate car, although the front lower bulkhead is .060 aluminum, not current style. The master cylinder mounting does NOT line up with the Star chassis cars, and there is a welded-in mount for them. It might be possible to make the shear plate fit. Fairly sure all the other shear plates fit, although a few might need some "massaging". I bought the main hoop "doubler" but never installed it, so I have the steel pieces still.
    I last ran it in 1998, crashed pretty hard and took off LF, RF and nose more or less completely. I don't think the frame got tweaked. Also pulled the rear susp radius rod, forward attachment bolts out of the frame. Both of these had previously been repaired with helicoil inserts, and the inserts pulled out.
    I had planned to repair and race FM again, but never did. I took a bunch of photos of the car to aid in putting to back together. I'm attaching them.
    In 1998 or 1999 I bought a new nose and front wings. Bought a used one-piece intake, with one of the throttle linkage attachment holes buggered up (needs welding, maybe). Bought the "new" exhaust system. I may have a new set (or pair) of Koni shocks... can't remember. I bought a battery tray & nose pole structure (might have been used). I bought aluminum brake hats, and some lightly used rotors. Car has iron calipers. My car has the separate MSD box and Rev box, but I bought the single unit from MSD (7AL?). All of this is on the shelf or in boxes. There's also a bunch of miscellaneous odds and ends, some used gear sets, etc. I have two sets of original styles (gold spider web) BBS wheels, plus the wheels that were on the car when I crashed. The inners and outers are pretty trashed, but the centers on that set may still be good. The engine has CCR on the rotor housings, and I never had it rebuild. It might have 60+ weekends on it, plus it's been sitting for almost 17 years. I sent it to Drummond to be re-sealed when the original wire seals broke, but it wasn't inspected or dyno'd. 99% sure it needs a rebuild (if it's not rusted solid inside!).
    I'm not going to race this car again, so someone should do something worthwhile with it. At a minimum, there is some value in the new parts, the engine core, transmission, spare wheels, etc.
    Take it all for $4000 (neg). Please contact me through ApexSpeed.
    Update: I have a pair of new front rocker arms, and three lower A-arms... at least one is used, the other two I'm not sure.
    LW
    Contributing Member Kazis31's Avatar
    Circuito Do Sol Portugal
    Liked: 384
    No pics attached??
    Maris Kazia ,CEO
    EuroKraft Inc Racing
    Circuito do Sol
    2014 Radical SR 3 RSX, 2x Tatuus FA 01
    BMW HP2 .BMW K1200 R.Porsche 996 Carerra 4s
    Liked: 52
    Pics.
    First time, I managed to delete the full text when I attempted to upload. So, for the encore I did it in two steps. Just not quickly enough, I guess.
    Houston
    Default "The engine has CCR on the rotor housings"
    Quote Originally Posted by LarryWinkelman View Post
    ... The engine has CCR on the rotor housings, and I never had it rebuild...
    LW
    CCR, aka Clayton Cunningham Racing, built Zoom-zooms out of an El Segundo shop situated between John Morton and Don Devendorf's Electramotive. I worked with him for the first third of the 1984 IMSA GTU championship campaign.
    Good luck with your sale
    "You GO Now"
    Rick
    Pennsylvania
    Default Sent you a PM
    Sent you a PM.
    Joel
    570.262.1018
    Liked: 291
    whats not to like?
    log books available?
    Liked: 52
    Default Logbooks
    Yes, I have the logbooks (3) and homologation certificate. Forgot that Jeff Davis ran the car in '90 (and won the Pro series). I'm pretty sure there are events from pre-1993 (when I got it) that aren't in the logbook, maybe not run with SCCA. Lots of space in book #3, I was on the first event... and curiously no tech notation from that event (at Route 66), even though it came back on a hook, with pieces falling off.
    Added a couple pics of the car in it's current state, for those who asked via PM.
    LW
    Scottsdale arizona
    Default Formula mazda info
    Hi there do you still have the formula mazda project for sale? I am interested, can you email me or pm, thank you in advance
    Liked: 384
    Wow.
    FM class is old enough to have car that needs full restore......
    Maris Kazia ,CEO
    Circuito do Sol
    Liked: 291
    Quote Originally Posted by Kazis31 View Post
    Wow.
    OUCH ...................LOL
    Contributing Member dsmithwc04's Avatar
    Indianapolis
    Liked: 177
    PM sent
    I race communist race cars.
    "Smokey, this is not 'Nam. This is bowling, there are rules." - Walter Sobchak
    Indianapolis
    Liked: 177
    Larry, can you call me at the number listed in my PM. Thanks!
    Liked: 52
    Default Sale Pending
    Sale pending
    Member bobbyrose5's Avatar
    Temple, Texas
    Is the car still pending sale?
  17. #15
    Temple, Texas
    Default Is FM still pending sale?
    Tried PM and email you Larry. Email seems to not be working properly or wrong address. Could you email me or call if chassis is still available?
    Scott A
    bobbyrose15@gmail.com
    cell: 832-712-6744
  18. #16
    Indianapolis
    Liked: 177
    It is not available anymore.
  20. #17
    Temple, Texas
    Quote Originally Posted by dsmithwc04 View Post
    Thank you
  21. #18
    Liked: 52
    Default Email
    Never got a message via ApexSpeed, or otherwise. Just tried to send, got "bobbyrose5 has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her."
  22. #19
    Temple, Texas
    Larry, I was just checking but is this car still available? Thanks you can email here or at my personal. bobbyrose15@gmail.com
  23. #20
    Senior Member gbmetcalf's Avatar
    Corning, NY
    Liked: 53
    Default Sweet Deal
    I hope someone gets this back on track.
    Aside from my FV I think FM is a cool class.
    G. Brian Metcalf
    72 AutoD MK4
    1991 Mysterian M2
    2014 ALR73 FV/FST
  24. #21
    Indianapolis
    Liked: 177
    I can personally assure you this car will be back on track.
  25. The following 2 users liked this post:
