    Fairfield, CA
    Default Smoothness of underside of car with diffuser
    All.
    I've built a floor for my race car that is uniform and "flat" from splitter/nose to diffuser inlet into the diverging diffuser. My question regards the "smoothness" of the "flat" bottom.
    I have protective rub strips around 1/4-turn fasteners that are teardrop-shaped and protrude into the air stream ~1/4". There are six of these strips ~3"W x 6" L on the bottom surface. Ride height is ~1.5" (37mm).
    Question: Should I be concerned about the effect of these strips upsetting flow and reducing downforce?
    Thanks;
    Greg
    Hoschton, GA
    Liked: 757
    No.
    You might see a difference in a wind tunnel but I wouldn't worry.
    Fairfield, CA
    Thank you.
    Paso Robles, CA
    Liked: 285
    My advice is to check the rules, some classes such as SCCA F1000 have a limitation on the quantity and size of skid blocks.
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
