Results 1 to 14 of 14
    Default The best F500 suspension elastomer springs
    The title says it all. I finally received a new batch of our very superior F500 suspension spring. These are very high tech elastomer materials that really work. Molded in a multi-cavity mold with a 3/8" diameter hole in them. They are 75 durometer Shore A scale and they really work.
    For instance at the 2014 Runoffs 3 or the top 4 cars used my suspension spring elastomers with our rocker geometry.
    $25 each.
    The picture below shows how they are implemented on our cars.
    Email me at jnovak at novaracecars dot com.
    S. E. Michigan
    Liked: 113
    With all the hype about the latest and greatest in racing - and the fact that some will pay huge prices for a "trick" part, I think it says a lot about Jay (in a positive way) that he sells the best F500 elastomers for $25.
    That class is so much the better for your involvement.
    Mark Silverberg - SE Michigan
    Lynx B FV & Royale RP3 FF
    240Z Vintage Production Car
    PCR, Kosmic CRG & Birel karts
    Thanks very much Mark.
    Liked: 227
    It's great to race in a budget class!
    Hoschton, GA
    Liked: 757
    Are they available with triple adjustment of high speed bump?
  10. #6
    not yet.
  12. #7
    Fairfield, CA
    As an FB lurker, do you have an estimation for how long these survive?
    In anticipation of the response, "it depends", I'll provide some info.
    Car stored off the floor with suspension in droop and unloading the material.
    Storage environment is 55 - 80F with low humidity. Not in direct sun and could be covered if suggested.
    Track environment is 60 - 105 F and 25% humidity. No direct sun except while on track.
    Usual USA tracks with their bumps.
    Thanks!
  13. #8
    Quote Originally Posted by ReynardF1000 View Post
    Thanks!
    Durability is not an issue unless there is severe heat as in exhaust heat near the elastomers. Typically our cars see about 3 or more years on the elastomers before they should be replaced.
    Under normal storage conditions as listed above we have seen no issues at all. The key element is to store or work on the car up in the air. This is to prevent a compression set which can happen if the car is left on the tires for extended time periods.
  14. #9
    oregon
    I am a newbie to these cars. Will these work on a 86 Red Devil?
    thanks, Jim
  15. #10
    Quote Originally Posted by ndpace View Post
    thanks, Jim
    I am sure they could be used, however they are much different than most others used in other cars and will require new rocker geometry to properly implement them. I have designed rockers for several othe cars and they work very well.
    The 2nd place car at the 2014 Runoffs is a KBS conversion that I built. It uses my rubbers and my rockers etc.
  16. #11
    Liked: 227
    thanks, Jim
    Jim,
    You may already know all this, but Red Devil is still making and supporting F500s. Here is their contact info.
    Race Cars of the Future
    Don Hanley
    406-494-8245
    Like all the chassis builders in F500, Don is very helpful. I have raced his cars since 1996, and have had nothing but good experiences and results with Don.
    Also, check out the 2 F500 forums.
    f500.us
    formula500.org
    Lots of good info and helpful people on both forums. F500.us is more focused on the technical aspects of the 2-cycle engines and CVT, while formula500.org is more general.
    Cory
  17. #12
    The newer Red Devil spring units are quite good. I have checked them on a rate dyno.
  18. #13
    Colorado
    Jay,
    I am familiar with your design of the elastomers. I have seen other photos of F500/F600 cars with what appear to be shocks? Are these shocks or are they enclosed elastomer systems of some kind.
  19. #14
    Quote Originally Posted by pauljensen View Post
    Jay,
    Those are enclosed elastomer canisters. Can be very effective. But IMO my system is much more like a linear spring. With my rockers I can make the rates and linearity anything I want it to be.
