Results 1 to 16 of 16
    Senior Member BURKY's Avatar
    Florida
    Liked: 444
    Default Standing Starts?
    I'm curious what RPM is a good place to start?
    Should we slip the clutch? Or just drop it?
    Liked: 1397
    Do you have enough torque to brake the tires loose dumping the clutch? If not don't dump the clutch. What type diff do you have? that will make a difference in how you approach a standing start.
    The best way is to sue some combination of slipping clutch and tires.
    Given the weight and traction of a F1000, I suspect that the MC tranny might not be up to a brutal launch.
    Florida
    Liked: 444
    Quaife.
    atlanta, ga
    Liked: 136
    Have you ever launched your street car or a street bike from a dead stop?
    Steady RPM and feeding out the clutch works for me.
    If it starts to bog, you let out the clutch pedal too quickly, and may need to dip it.
    Practice before the event.
    9k rpm sounds about right.
    13k and dumping the clutch is not the ticket.
    Florida
    Liked: 444
    Does a Yugo or Vespa count?
    Thanks for the advice.
    atlanta, ga
    Liked: 136
    https://instagram.com/p/zbBu5tjecv/?modal=true
    2 things:
    Who ever is on the limiter has no mechanical sympathy for what is between their legs, and
    I have no idea why that one bike is smoking like a 2 stroke!
    Good launch ='s no bogging, perfect clutch engagement.
    GREAT launch ='s the above and carrying the front wheel 4" offa the deck through first gear!
    Alpine California
    Liked: 273
    Default In car standing start video
    Here's some decent in car video of a standing start we did at Portland USF1000 race last year.
    The car in front of me not so good start.
    https://www.youtube.com/watch?v=N9B3Gl2PEIo
    We did 2 standing starts last season, they are a ton of fun!
    Gary Hickman
    Edge Engineering Inc
    FB #76
    We broke a trans case on a launch. Do not know if there was another issue, just know that the case cracked about 1/4" right at the output shaft.
    I suggest being a bit gentle, whatever that means.
    Indianapolis, In
    Liked: 30
    The hotter the tires are the harder it is on the drive train also.
    Australia
    Im having to use about 11k RPM and slip the clutch almost all the way through 1st gear. if the wheels stop spinning the engine will bog. a tiny amount more clutch is all that is needed to fix that and keep the wheels spinning a little, you need to maintain a little bit of wheel spin to maximise traction. (slip angles etc...)
    Florida
    Liked: 444
    I guess we'll find out tomorrow... I've arranged a 30 minute test for standing starts at PBIR in the morning.
    Thanks for all the advice!
    Senior Member jaltaman's Avatar
    Salt Lake City
    Liked: 66
    IMO 11K seems a bit aggressive, but it's your engine. I used less than that - closer to 8500 RPM, and never had an issue afterwards.
    It's all about how you let the clutch out - you have to slip it, and slip it well (without jumping the start - ahem, Mr. Hickman).
    Alpine California
    Liked: 273
    Quote Originally Posted by jaltaman View Post
    I agree with John, 11k too many revs likely tearing stuff up.
    Hay if the flagger aint lookin' whats a 1/10th tire revolution....see it in F1 all the time.
    Gary Hickman
    FB #76
    Salt Lake City
    Liked: 66
    Flagger?!?! There was a flagger?!?!
    Man, you have good eyes!
    Salt Lake City
    Liked: 66
    And yes, just bustin' yer chops, my friend!
    Alpine California
    Liked: 273
    I'm full on jealous that the East Coast boys are doing a standing start at Road Atlanta.
    If it wasn't a 5k tow for me I'd be there, RA is one of my all time favs.
    Gary Hickman
    FB #76
