Results 1 to 9 of 9
Thread: Shifter cable
    cambridge, massachusetts
    Default Shifter cable
    Anyone have a description or picture of the cable connection [ tab/ bracket location] at the engine?
    Will
    What kind of engine?
    Silver Spring, MD
    Default shift cable bracket 2007 GSXR 600
    Below are pictures of the throttle cable attaching bracket on a 2007 GSXR 600. Purchased from:
    Piontek Engineering Inc.
    125 W. Auburn Trail
    Brighton, MI 48114-5000
    810 991-1148
    Suzuki
    Thanks for the pictures. I have fabbed a bracket that bolts to the sprocket cover, cable comes up from floor pan. Just not sure if it's the best place.
    Will
    Quote Originally Posted by Vulnavia View Post
    Will
    Too much heat down there IMO.
    Atlanta, Georgia
    Over the years we have melted just about everything that can melt or burn within a foot or so from the motor and exhaust pipe. Clint covers EVERYTHING in heat shielding - on it and/or next to the heat source and this includes the throttle cable. It is amazing how far away heat will travel on the chassis tubing, eg - bubbling the fuel inside the fuel cell by receiving heat from the bottom chassis tubing. Once the exhaust pipe got loose and sat next to the rear brake caliper, result - boiled rear brake fluid and no rear brakes - yikes! And we don't even want to talk about what happened to Clint at the Runoffs due to heat.
    In case of doubt - heat shield it or suffer the consequences - it is better to err on too much heat shielding than not enough.
    HTH,
    Fairfield, CA
    Ceramic washers separating conductors.
    Air blow - something no one wants to do but works well.
    Atlanta, Georgia
    Quote Originally Posted by ReynardF1000 View Post
    Please provide the rest of these two stories so that we all can learn.
    TIA,
