some one must need one of these
friend us on FaceBook search "velocity haus"
like on facebook search "velocity haus Engineering"
Velocityhaus.com
velocityhaus@gmail.com
@Velocityhaus2 instagram
price drop for the last time !
Velocityhaus.com
Price drop till thanksgiving day !
Velocityhaus.com
Until thanksgiving day !
Velocityhaus.com
Greg,
can you put up a photo of how they look on the car? Not getting how they attach to the car. What would be needed to adapt them to a Citation?
Thanks!
Brad
this how it works ..
if you use an LD200 likely work on the Citation if you use the Staffs gearbox you'd likely need an adapter plate for the gearbox to rear assy like I did for the JFR install
the front would likely work it is made to sit on the 1x1 tube in the top of the front bulkhead Im sure the Citation has one of those, correct ?
if you had pix of the front and rear of the Citation I could tell you for sure
call if you like
(408) 832-3114
Velocityhaus.com
I'll look and see what might be needed.
Brad
no PM's as of yet from either of you ...
maybe try my email or cell phone
Velocityhaus@gmail.com
sales@velocityhaus.com
(408) 832-3114
Regards
Greg
Velocityhaus.com
bump
Velocityhaus.com
still have stock !
Velocityhaus.com
I have a spare LIKE NEW COSWORTH refurbished ( brand new PCB not fixed)
sealed etc
These are not available new anymore !
Again the only thing that is used is the aluminum box the PCB is housed in
$1150.00
Velocityhaus.com
COMPLETE REAR WING
Excellent shape
either high speed or high downforce upper elements, your choice
long end plates
$850.00 shipped
I will include Webster LD200 end cover for $300.00 extra
Long or short VD mount plates and hardware $170.00
cover is from post already posted
Velocityhaus.com
everyone loves pictures
here is the ECU I have for sale
Velocityhaus.com
Will they fit my Tiga sc84 sports racer?
Bolt circle is 3.75" dia.
Drive pin diameter is .520" dia.
The center hole is 2.25" dia.
These fit a late model VD F2000 primarily
That is not to say they will not fit a Tiga SC84
If the pin dia is an issue I could likely sell you VD pins to make that part right
MOST cars are 3.750" BC and 2.25" dia center hole
I don't know the specs of the Tiga SC84
I had a Tiga 77 FF1600 a long time a go and it was the 2.25" center hole and 3.75" BC but had studs not a center lock arrangement
Velocityhaus.com
I have one each NEW un-mounted brand new Aerocraft OEM Late model VD side pod floors
$400.00 each plus shipping of your choice
Buy both and I will ship to the lower 48 states
These are both brand new made 3 months ago for a customer that changed their mind
very stiff and light very nice parts
Rick does a very good job on OEM style VD parts always a great fit
these are no exception!
Velocityhaus.com
new price
Velocityhaus.com
new prices
Velocityhaus.com
price adjustment this is it they are BRAND NEW !!
Velocityhaus.com
I have a completely Gear Daddies rebuilt UNUSED LD200 since BRAND NEW 13/36 R&P and rebuild
complete gearbox without gears and used but very nice input shaft
$5700.00 without gears OBO
TDI light aluminum diff
can come with output shafts loaded with LIKE NEW Aluminum CV housings and NEW CV tripod bearings for a +$450.00
ready to go into the "cooler" to ship
Late model VD input shaft NEW $625.00
good used late model VD input shaft $485.00
Velocityhaus.com
Pictures of LD200
Velocityhaus.com
lots of looks but no buyer yet
dropped the price !
Velocityhaus.com
new price
Velocityhaus.com
This will be the very last price drop
Bear in mind this is for all practical purposes a NEW box
and IF you could get a new box right now it would cost nearly double the price I have listed here.It is very doubtful Hewland's price will do anything but go UP in the future
Again, since this box was rebuilt by Gear Daddies It has been UN USED and not even mounted to the bell housing adapter
Velocityhaus.com
newer price
Velocityhaus.com
So I lied I guess but this will be the very last price reduction
needs to go to a new home ASAP !!
Velocityhaus.com
bump still have this available
Velocityhaus.com
bump
Velocityhaus.com
Pm sent
RaceDog
Messenger Racing
Muleshoe, Texas USA
Send me the backspace
806-946-7252
RaceDog
Messenger Racing
Muleshoe, Texas USA
NOW till BLACK friday $1000.00 shipped !! ends at mid nite friday eve
Velocityhaus.com
NOW till friday at midnight $750.00 SHIPPED
Velocityhaus.com
Now till this friday eve midnight
$410.00 shipped
Velocityhaus.com
free shipping to the lower 48 states till this friday mid nite
Velocityhaus.com
$700.00 for both AND FREE SHIPPING TILL THIS FRIDAY AT MID NITE
Velocityhaus.com
Wishbones at lowest you will ever see them
2 upper fronts
2 lower fronts
2 upper rears
2 Brand NEW bearing nuts in lower fronts
$1550.00 shipped to the lower 48 stated
wide aero tube
dark grey
Velocityhaus.com
buy complete uprights with NEW bearings lower pins and upper steering arm bracket and a caliper bracket of your choice LD20, LD19 or PFC radial
just add your caliper and hub parts
NOW till friday at mid nite only $425.00 complete as described and assembled While supply lasts
AND SHIPPED FREE to the lower 48 states !
Velocityhaus.com
