Thread: 2015 GCR
    Silver Spring, MD
    Default 2015 GCR
    While reading the new 2015 GCR for the F500 class “spec line items” I can’t find Note #5. Does anyone know where I might find it?
    http://www.scca.com/assets/2015%20GCR-January.pdf
    GSXR600 (03-13), 875, 30mm Flat Plate Intake Restrictor, stepped exhaust headers are not allowed, Notes 2, 3, 4, and 5.
    Notes:
    1. Any model thermostat housing or water outlet elbow may be used. The water bypass may be blocked. Either upper or lower cylinder head water outlet may be blocked in any safe manner to facilitate use of a single water outlet.
    2. Fasteners, cooling system and oiling systems are free.
    3. Clutches are free as long as no mods are made to the engine to accommodate the replacement clutch.
    4. Competitors must be able to supply a printed factory service manual for the year of engine being used to tech upon request
    Note 5 is also not in the 2014 GCR. Probably an oversight or perhaps they left it empty so that they could put an errors and omissions change in the rules any time.
    Contributing Member Terry Hanushek's Avatar
    New Jersey
    Liked: 59
    Note 5 is the new double secret restriction - you will be notified in impound.
    T
    Quote Originally Posted by Terry Hanushek View Post
    T
    Cool, thanks Terry.
