Results 1 to 16 of 16
Thread: 86 reynard
    Valley Hi,Ohio
    Default 86 reynard
    Where and if the 86 reynard has a chassis plate? Or number somewhere?
    Lee
    Liked: 3787
    Most Reynard chassis plates i have seen were riveted on the dash.
    Some are just laying in my toolbox...
    Senior Member ghoneycutt's Avatar
    check the roll hoop.
    SF86 Reynard FC
    FRCCA http://www.formularacecarclubofamerica.com
    Bill Scott Formula Car Series http://www.bsfcs.com
    BMod Autocrosser http://www.nationalroadrally.com/
    Senior Member gord leach's Avatar
    sask,canada
    front roll hoop/dash. bottom left side near lower frame rail stamped in.
    later Gord
    BTW...only toilets need doors
    www.blurredvisionracing.com
    Valley Hi,Ohio
    Default THANKS
    WHEN I GET BACK I WILL CHECK AFTER TRIP TO CAR WASH.!!
    LEE
    http://www.metroevents.com/jordaneng/index.htm
    Valley Hi,Ohio
    Default roll bar
    It has an SCCA tech sticker on the rollbar so it muct have had a log book at one time.I will check the rollbar when I get home.
    Lee
    Contributing Member blackbmwk1200r's Avatar
    Great Falls, VA
    This is what it looks like; however, can't remember where it was. Maybe someone else can tell from image.
    Sid Smith
    Valley Hi,Ohio
    Default 85 !!
    Tag on bulkhead by left thigh just says : Reynard 85 - 032
    cannot find your standard Reynard tag.
    does that make it an 85 or ?
    what side would the SCCA stapping be on the rollbar? or where?
    Lee
    Liked: 601
    Default 85 Reynard
    Makes it an 85 Reynard
    Valley Hi,Ohio
    Default Scca numbers?
    SCCA numbers? On the roll bar?
    Liked: 601
    Default SCCA numbers
    There should be a small hole drilled in the main roll hoop, next to which should be the SCCA log book number.
    Contributing Member SWMyers's Avatar
    Saline, MI
    Liked: 19
    Quote Originally Posted by LAJ View Post
    Lee
    My Reynard was an '89 per the metal tag riveted to the roll hoop inner cover. But the number stamped in the chassis (in the frame by the dash hoop) was 88- something. All the documents, (log book and homologation cert, etc.) listed it as an '89.
    Maplewood, N.J.
    Default Hello !
    Quote Originally Posted by ghoneycutt View Post
    John Bachman suggested that I contact you as I just picked up his 86 Reynard. It is now at my house in New Jersey. I am just digesting what I purchased. I spoke with AJ and he had some stories about the car to tell me. So I am casting about to learn what I can learn about it. I know it is foolish, but it would be nice to find the original rear wings. I know they were too big and the the old one was lost in Fred's garage, but I like the way they look. On a more serious note, I do intend to put the car back together, but it will not happen soon. I still have to fix my daughter's Van Dieman and I am planning what to do with my car. Yours, Paul 862-668-7630
    near Athens, GA
    Liked: 830
    Quote Originally Posted by SWMyers View Post
    The 88 is most likely the SCCA Region number that issued the original log book and stamped the roll hoop. That would be Arizona Border Region - around the Tucson area. That number is generally the Region number followed by a consecutive number of the log books issued from that region. Not related in any way to the year/model of the car.
    Liked: 601
    Default 86 Reynard
    In this case no, it was the year the frame/chassis was made. It was (obviously) not assembled and shipped to the states until the next year, thus the 89 designation.
    Tacoma, Washington
    Liked: 210
    Hey guys, we had a 1989 and a 1990 Reynard. They BOTH had the chassis plates riveted to the rear fire wall just over the drivers right shoulder as I recall.
