Results 1 to 2 of 2
    Senior Member gbmetcalf's Avatar
    Corning, NY
    Liked: 53
    Default Full flow systems
    My engine is set uo for full flow but I have never delt with a full flow system. I know it comes out the pump goes thru the remote cooler or filter then the comes back into the block somewhere. How do you block off the stock cooler connection? Is there any photos of a full flow system out there? I'm slightly confused.
    G.
    G. Brian Metcalf
    72 AutoD MK4
    1991 Mysterian M2
    2014 ALR73 FV/FST
    Lexington KY
    Liked: 50
    Lots of pictures and write-ups. Do the following BING, GOOGLE, etc. search for dozens:
    "VW FULL FLOW OIL SYSTEM PICTURE"
    Yes. You need a Full Flow Pump cover and a Oil Cooler blockoff-bypass plate for the top of the engine. Typical is the BugPack 3045. But there are many others. We still have both types in stock. (there are many other full flow ways to plumb the system also.)
    SR
    859-252-2349 or
    859-339-7425
    http://www.sracing.com
