Results 1 to 11 of 11
Thread: Mychron 4
    Senior Member gbmetcalf's Avatar
    Corning, NY
    Liked: 53
    Default Mychron 4
    Can a Mychron 4 be used in a Vee? Never used one before but picked one up real cheap from a cart racer getting out of carts.
    G.
    G. Brian Metcalf
    72 AutoD MK4
    1991 Mysterian M2
    2014 ALR73 FV/FST
    delaware
    Default my4
    I think the my4 tach is for single cylinder use.
    It may give a tach readout, but it will not be correct.
    Of course any temp sensors should work fine.
    S. E. Michigan
    Liked: 113
    As the mychron picks up an inductive signal off a spark plug wire the dash could care less how many cylinders the engine has (as long as the signal is only getting picked up from one plug). The Mychron4 manual states that the dash has RPM factors of x1 , x2, /2, /4.
    For the VW engine picking up a signal from a plug wire you would want the X2 multiplier as the cylinder only fires every two revolutions.
    Mark Silverberg - SE Michigan
    Lynx B FV & Royale RP3 FF
    240Z Vintage Production Car
    PCR, Kosmic CRG & Birel karts
    delaware
    Default my4
    Wow!
    Checked it out and wanted to correct my post.
    Mark beat me to it, he is correct.
    Shelbyville, TN
    Liked: 94
    I used an Mychron 3 Kart Gold for years on my Vee. Worked great.
    Scott
    Liked: 947
    I am currently using a mychron 4 with the GPS antenna on my Zink CF. It is set up as a data logger. I get lap times, RPM, GPS speeds, lateral g's and track position.
    I made sure I had about 8 turns of tach wire on the coil wire for the RPM signal. Works very well.
    Regards,
    Dan
    Pueblo, Colorado
    Default Mycron/ gages
    With everybody switching to computers there should be lots of gages available. I need a VDO oil pressure gage for my vintage car. Needs to be the type with the metal U-Clamp; not the new plastic screw on retainer. Probably interested in temp gage also. Thanks, Bob
    Vancouver BC
    Liked: 49
    Bob, are you looking for an electric or mechanical oil pressure gauge? I had both at one point but not sure which I still have. I think one of them was the type with the metal clamp thing.
    Pueblo, Colorado
    I am looking for the electrical type. Thanks,
    Guadalajara, México
    Quote Originally Posted by Mark_Silverberg View Post
    If we connect it to the tach cable (directly to the coil) it should be /4?
    Liked: 58
    Quote Originally Posted by enrikerace View Post
    I believe you want /2. Each cylinder fires once per two revolutions. So the coil sparks 4 times every two revolutions, or 2 times for every 1 revolution. So /2 to get the right rpm number.
    1993 Citation FV
    NEFV - 2022 Champion
    NERRC - 2022 Champion
