Results 1 to 8 of 8
    Mississauga, Ontario
    Liked: 902
    Default BDA fuel pressure, regulator
    Hi all,
    BDA 1600, twin 48DCOEs, vintage Atlantic mill. Thoughts on fuel pressure and a decent regulator?
    Cheers
    Bill Tebbutt
    Petaluma, CA
    Liked: 565
    2.5 to 3 psi, a Holley regulator (like this one: http://www.holley.com/12-804.asp ) is the standard one used
    Ethan Shippert
    https://www.norwestff.com
    Geneva IL.
    It's been over thirty years but I remember using 3.5 to 4.0 psi and the Holley one to four lbs regulator. I believe we used dash six hose and fittings.
    Ed Midgley
    Member giffo's Avatar
    Australia
    Quote Originally Posted by teamwisconsin View Post
    Use this setting & from memory Steve Jennings has some info on his website on this also
    Banned Modo's Avatar
    DC Area
    Liked: 19
    if u don't need one (float needle valves properly cut flow off), don't use one, with a fierce cam and first to second and second to third shifts you will need all the gas possible quickly and not limit HP by the regulators ......... definately find out who knows and has used them ....... put regulators on the three pumps on my air cooled super vee and even raising them to the highest it limited the HP, had to eliminate them in a wet sump system - Holley monster and two small electric box pumps (wet sump no longer allowed)
    Liked: 902
    Default Thanks guys
    Turns out I have the correct regulator, as suggested. But it came w the car years ago, I never checked it. And guess what? It doesn't regulate. Runs at 7 psi all the time regardless of how you adjust it. I assume the diaphragm is lunched. New one to be picked up tomorrow.
    Cheers
    BT
    DC Area
    Liked: 19
    It's a good time to go over why you guys are obsessed with using a regulator, what are the pros and cons in a rapid rise power creation engine ......... anyone or is it 'why not', or another part to fail and connections??? I would think it's binary, either the float needle valve works (no regulator) or it doesn't (regulator, hopefully non-restricting value used) ......
    I use this one ......... https://www.pegasusautoracing.com/pr...s.asp?RecID=86 ............ for my FC 32/36 with no problems, has a pressure relief valve in it, (guess that is a regulator LOL) ......use this because fuel cell has a top delivery port so needs priming with mechanical pump, and, I like the on board filter, just loosen and twist to empty contents, is a bendix type pump or I used to have one on my tr3 that was made by bendix
